Hello again,
I came across a cheap 2008 Macbook unibody MB467LL/A and decided I would go for it to see if I could repair it.
I just wanted to note my progress here and if anyone wants to chime in feel free.
(I currently have a shitty phone (mine broke--no couldnt fix it
) so no photos)
So when I received the laptop first thing I did was plugged it in. The magsafe started blinking green after I pressed the power button. On and off. (Power not getting to where it needs to go). Removing the battery gave me an amber flashing light when I plugged it in.
So I pulled it apart and saw it was covered in whatever spilled on it. It was very hard to get what appeared to be corrosion off the board. I used qtips with alcohol. After a while got it clean. Tried again and same problem.
The DC adapter was especially corroded. It seems like it shouldnt be broken since it was doing something but testing it with a volt meter is proving that it could in fact have something gone bad on it. I am going to look at that later.
After I cleaned the board I inspected it. I noticed that it appeared to be missing a couple components based on the look of some of the pads. Sure enough it is based on the board view. Missing C6915, C6880, and a corner of the plastic on T3902 is broken off. I am still testing components and looking for anything missing. My guess is these were separated from the board slightly and I knocked them off when I was cleaning it. Or its possible they were missing before. Last, I could have just knocked good pieces off the board. Still trying to verify if anything else is missing. I know A continuity check on fuses looks good so far, but not 100% sure I checked them all.
Side note: board view says there is something suppose to be near C68820, R6882, however its not there (and doesnt look like it should be), and when I looked at photos of other boards it wasnt there. So I am a bit confused if anyone has any input on that. Also if you have a high resolution clear board images (top/bottom) that would be helpful. I cant find one thats the same and clear. The board is 820-2327-A.
I will be working on it and updating this original post. I want to see if I can confirm the Magsafe DC board is in fact dead or not then I can either repair it or a order a new one for around $10 on ebay. The part for this is 820-2361-A.
Happy April!! (its spring finally!!!)
