HP 6735s ok power but nothing on screen
  • rippergr
    • May 2014
    • 345
    • Ελλάδα
    Hello all,
    I have a 6735s HP which powers on but there is no image on screen. Caps lock flashes 5 times.
    I searched in forums and they said to reflow gpu and northbridge. I did that but nothing changed.
    Can someone guide me what to measure to see if it's northbridge or GPU (or something else)
    Thanks.
  • dj_ricoh
    • 2073
    • uk
    Re: HP 6735s ok power but nothing on screen
    Change bios battery if its AMD and test mant memorys
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3577
      • slovakia
      give NB heat to 100c and check for screen.
      • claudyu07
        Claudyu07
        • May 2014
        • 164
        • Ireland
        hook it up to external aswell
        • rippergr
          • May 2014
          • 345
          • Ελλάδα
          I changed cmos battery and change memory.
          I reflowed GPU and already checked it in external monitor.
          Nothing changed.
          The caps lock still flashes 5 times
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3577
            • slovakia
            • rippergr
              • May 2014
              • 345
              • Ελλάδα
              you mean put it in oven or put in preheat in 100c ?
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3577
                • slovakia
                just heat NB to 100c with preheater, put al foil under the board to heat only NB not GPU
                • Djosla
                  • Dec 2012
                  • 246
                  • Montenegro
                  6735s has nb and gpu in same chipset...
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • grimacelord
                    HP 15-EH1070wm - Black Screen With Power LED.
                    by grimacelord
                    I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
                    First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
                    01-28-2023, 10:50 AM
                  • joaquinmjuan
                    Canon TS8350 Screen Freezes on Power On
                    by joaquinmjuan
                    Hello, I have a Canon TS8350 printer. The problem is that when I turn it on, "CANON" appears on the screen, but it never goes away. You can leave it on for a whole day, and it doesn't go away. Does anyone know how to fix this? I've tried unplugging it, but nothing. I've also tried holding down POWER, but nothing. In fact, once it turns on, it can't be turned off with the Power button. I've also held down Power and then plugged it into the Power supply, and the power light flashes once and doesn't turn on, but then when I press Power again, it turns on. Currently, it's a nearly new paperweight,...
                    05-07-2025, 12:26 AM
                  • Alicat
                    Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                    by Alicat
                    Stopped by this site trying to fix my parents Panasonic Plasma TV.
                    Model number is TH-50PZ85U
                    Power comes on and the red power light stays on solid.
                    Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                    I also hear a few clicks.
                    I also think my parents said there was a thunderstorm and the TV failed after that.
                    Section 6 in the service manual talks about power and no screen,...
                    10-30-2024, 10:09 AM
                    03-31-2024, 02:12 PM
