HP 1000 dead but charging light on
  • sonunigam
    • Aug 2013
    • 151
    • Pakistan
    Hello all,
    I'm in a trouble that one HP 1000 wont power on but charging light on. when i check 3.3 Voltage on Switch. these are present. Can anyone tell me the solution?
    I'll be grateful for that.
    Thanks a lot
  • vikram.syc@gmail.com
    • Jul 2014
    • india
    Re: HP 1000 dead but charging light on
    pls update bios file
    • esqmooo
      HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
      by esqmooo
      Hello everyone.
      This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
      Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
      Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
      I tried long pressing on the power button, after several seconds it would go off then when the button is released...
      03-11-2025, 03:57 PM
    • Elecfronicsssss
      DA0NJJMBAG0 charging light blinks
      by Elecfronicsssss
      Laptop motherboard DA0NJJMBAG0
      PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
      CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
      GUIDE ME WITH THE PROBLEM..
      SUMMARY-
      1.NO 1.8VOLTS ON BIOS PIN NO 8.
      2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
      05-12-2025, 02:32 AM
    • esqmooo
      HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
      by esqmooo
      I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
      03-07-2025, 05:55 AM
    • Rav_tangle
      MacBook Pro 2011 turns on with keyboard light , screen dead
      by Rav_tangle
      Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
      I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
      Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
      is this...
      05-31-2024, 04:09 PM
    • robka
      MacBook Pro 2018 - A1990 Dead - not charging - only 5V
      by robka
      my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
      I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
      The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
      After that the Macbook was dead. It isn't charging anymore.
      The USB-C Port where the charger was plugged is burned. Also The Cable and the...
      03-02-2024, 02:58 PM
