Lenovo G550, no image, only backlight
  • claudyu07
    Claudyu07
    • May 2014
    • 125
    • Ireland
    hi Guys, have here a Lenovo G550 that i got in a job lot .
    When it powers on i only have backlight but no image,
    External is fine.
    Intel celeron CPU with Intel Graphics.
    I have tried different screen and different video cable.
    Any ideas?
  • dj_ricoh
    • 2073
    Re: Lenovo G550, no image, only backlight
    Cook the board
    • claudyu07
      Claudyu07
      • May 2014
      • 125
      • Ireland
      Originally posted by dj_ricoh
      Cook the board
      Have no idea what you mean thanks
      • claudyu07
        Claudyu07
        • May 2014
        • 125
        • Ireland
        Anyone?
        • tata123
          • Nov 2013
          • 104
          Check Filters and Resistors near the LCD Connector!
          You need a schematic, but you can check if there is a damage the parts have a inscription with (FL, L, P (fuse)).
          You can also heat the Intel Chip up, to check if this is a BGA Problem!
          • claudyu07
            Claudyu07
            • May 2014
            • 125
            • Ireland
            Thanks.
            i will check components and if nothing wrong will trow it on the rework machine for reflow and see after. thanks
            • masud
              • Jul 2011
              • 317
              • Bangladesh
              You need a schematic, but you can check if there is a damage the parts have a inscription with (FL, L, P (fuse)). and
              check 2/3 small transistors near the LCD Connector too.
              • claudyu07
                Claudyu07
                • May 2014
                • 125
                • Ireland
                Good morning guys, i did reflow and same problem. now i will start looking for broken transistors , fuses....
                Will post back.
                • claudyu07
                  Claudyu07
                  • May 2014
                  • 125
                  • Ireland
                  Ended up buying another motherboard . turned out was cheaper than time spent to try fix .
                  Maybe in future will come back to this board
                  • dj_ricoh
                    • 2073
                    Now that you change it cook the old one.
                    • claudyu07
                      Claudyu07
                      • May 2014
                      • 125
                      • Ireland
                      im not familiar with the term 'cook' if you can explain please.
                      New motherboard seems to have problem with webcam. not detecting it . bought new camera and cable and problem so again mobo problem...
                      • andrhouseolly
                        Lenovo X240 - motherboard replacement for X250, no image.
                        by andrhouseolly
                        Friends. I beg you to help me in this situation.
                        Lenovo X240 with a video problem. Native Intel drivers are not installed,
                        after installation, a black screen. It works with the standard Microsoft driver.
                        Understanding that there are problems with the video core,
                        I ordered a motherboard from Lenovo X250.
                        The laptop turns on, starts up, there is no image on the internal display.
                        The image is output to the external monitor.
                        I ordered another motherboard from Lenovo X250.
                        07-12-2024, 03:02 PM
                      • coasterghost
                        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                        by coasterghost
                        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                        System Hardware:
                        Processor: AMD Ryzen 7 PRO 5850U
                        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                        09-08-2025, 10:46 PM
                      • marcelofct
                        Lenovo Legion 15Ith6 no image
                        by marcelofct
                        I have this Lenovo Legion that only gives an image on the external screen
                        I have tried several screens, flex cables, and nothing is detected in any way. I leave the following image so you can see the voltages and please help me.
                        It is a lenovo Legion 15Ith6
                        S/N: pf4f91at
                        I appreciate it...
                        02-01-2025, 10:53 AM
                      • Salem Aboshala
                        820-00138-A got image but no backlight
                        by Salem Aboshala
                        Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
                        I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
                        History: my laptop backlight stopped working without any reason.
                        Symptoms:
                        I have image on screen using my flashlight.
                        I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
                        Keyboard backlight still working and can be adjusted normally.
                        Since two days I tried to follow all similar...
                        06-11-2024, 03:02 PM
                      • zaurus81
                        Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
                        by zaurus81
                        This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
                        The board is equipped...
                        01-16-2025, 03:54 AM
