Lenovo G550, no image, only backlight
    hi Guys, have here a Lenovo G550 that i got in a job lot .
    When it powers on i only have backlight but no image,
    External is fine.
    Intel celeron CPU with Intel Graphics.
    I have tried different screen and different video cable.
    Any ideas?
    Re: Lenovo G550, no image, only backlight
    Cook the board
      Originally posted by dj_ricoh View Post
      Cook the board
      Have no idea what you mean thanks
        Anyone?
          Check Filters and Resistors near the LCD Connector!
          You need a schematic, but you can check if there is a damage the parts have a inscription with (FL, L, P (fuse)).
          You can also heat the Intel Chip up, to check if this is a BGA Problem!
            Thanks.
            i will check components and if nothing wrong will trow it on the rework machine for reflow and see after. thanks
              You need a schematic, but you can check if there is a damage the parts have a inscription with (FL, L, P (fuse)). and
              check 2/3 small transistors near the LCD Connector too.
                Good morning guys, i did reflow and same problem. now i will start looking for broken transistors , fuses....
                Will post back.
                  Ended up buying another motherboard . turned out was cheaper than time spent to try fix .
                  Maybe in future will come back to this board
                    Now that you change it cook the old one.
                      im not familiar with the term 'cook' if you can explain please.
                      New motherboard seems to have problem with webcam. not detecting it . bought new camera and cable and problem so again mobo problem...
