is it possible to run the motherboard by removing the ati gfx chip. can it using as a intel integrated gfx board . or how can i convert ati gfx board to intel integrated gfx board on dell N5010 without replacing motherboard
dell inspiron N5010
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
Channel: Schematic Requests ONLY!
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
DELL Vostro 3450 / Dell Inspiron 14R N4010 DAV02AMB8F1 Schematic & Board View...
Channel: Schematics and Boardviews
by jasonbay13it was working yesterday, i opened it up and saw this mess. boardview and schematic uploaded for convenience.
PU200
pin 17 vreg5 = 0v ~ solder joint was corroded and flicked right off with my probe, was able to get clean and reflow, rest look fine.
pin 8 vreg3 = 0v
pin 13 en = .2v
pin 1,6 entrip1,2 = 0v
b+ and b++ = 19.5v
+5valw = 0v & 25+ohm to ground
+3valwp = 0v & 25+ohm to ground
i cleaned the board up just a little and can get more pics.
where should i be looking? thx... - Loading...
