Aspire 4750 4750g no power
  • snsent
    • Nov 2010
    • 103
    • Malaysia
    HI,
    I got Acer Aspire 4750 with NO POWER / NO CHARGING problem. Already change both of 220uf 6.3V but still got same result. I also reprogram BIOS IC but result still same. Please help me.
  • dj_ricoh
    • 2073
    • uk
    Re: Aspire 4750 4750g no power
    Check for diods near dc connector.
    If you find lift it up and your good to go.
    Diodes in acer near dc connector are for discharge. They tend to fail and open and make short to ground.
    • sasser
      • Dec 2012
      • 365
      • Malaysia
      dj_ricoh i found pq32 is low resistance to gnd. but not check diodes that u mention.
      • kafarda
        • Jul 2019
        • 21
        • Nigeria
        For my own case, I reprogrammed the bios chip (25Q32BV) but computer (Acer 4750g i5) doesnt turn on (using power supply or battery), just a ink of greenish led at the ethernet port when inzerting charger, any suggestion please.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • Bonaventure Vigil
          ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
          by Bonaventure Vigil
          Dear All,
          Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
          At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
          12-12-2024, 10:22 AM
          03-31-2024, 02:12 PM
