How to prepare pads on ic beffore reball
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Hello.
    I have some problems on some intel ic to prepare pads for new balls. wheen i try to put some solder with iron on it it just dont want to.
    i using kingbo past.
  • highpulse
    i hate HP
    • May 2013
    • 1489
    • portugal
    Re: How to prepare pads on ic beffore reball
    well use it well using good goodwick , and a good hot temperature , i usually scratch a bit does very dark pads , then i scratch them gently with gootwick soaped in tin lead
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • sancho76
      thickness of thermal pads for Alienware M15 R1
      by sancho76
      Hi, somebody knows the thickness of thermal pads for M15 R1? Or if someone have this Alienware model, can take measure for original thermal pads.
      02-01-2025, 03:19 AM
    • dbuergi
      Restore solder pads for SMC on MacBook A1466
      by dbuergi
      i got a A1466 logic board for spare parts but it looks like the SMC ist bad. I got several spares but somehow i was too fast while removing it and ripped some pads off. You can see the damage attached.
      Just for experience i would like to restore the lost pads but before i start (haven't done this before) do you have some hints or tutorials how to do it?
      As written i want to improve skills so it doesnt matter if it takes longer.
      12-29-2024, 10:24 AM
    • supravit2000
      Sony PS4 ADP400DR - help needed figuring out shorted pads under capacitor C 31
      by supravit2000
      Hi!
      A friend of mine gave me a dead PS5 to look at. I am totally inexperienced, but when a damage is simple (i.e. failed DAP41 on PS4s, etc.), when replacing just the IC and the other very common failing parts of these consoles, problem is fixed. So I checked the voltage of the PSU - none was present. Model is ADP 400DR. I have a bunch of spare parts around, so first thing I did was to replace the IC DAP 053 (they seem quite expensive, so I put a replacement unit - TEA2016AAT. When plugged to the power outlet, 12V did come present.
      So I reassembled the PS5 and pressed the power...
      07-20-2024, 07:26 AM
    • Forumzboard899
      PAD repair? What are pads?
      by Forumzboard899
      This is a Roland MC-505 synthesizer I bought used years ago and 1 of the knobs was bent.
      Eventually it started 'ghost editing' by changing the parameter of this knob on its own.
      I resoldered the 5 pins on this knob (the two larger solder spots above these 3 smaller ones is for the same knob).
      Then it started happening again, or maybe the knob stopped working totally (I set it aside months ago and forgot about it).
      I bought a replacement knob/Potentiometer but when I recently opened it up, it seems the previous repair...
      03-07-2022, 05:30 PM
