HP G61 DA00P6MB6D0 no lcd backlight
  • ahmetozay
    • Jul 2013
    • 73
    • turkey
    Hi, This laptop came as broken lcd. I changed the lcd but there was no backlight. It is ok on external screen. What i have done so far is;
    I changed the inverter
    I changed the ENE controller
    I changed the Lcd flex cable
    Still no backlight. The measurements are below;
    Inverter 4 pins as in standbye state
    1- 18.7v
    2- 14v
    3- 0.17v
    4- 15.7v
    Inverter 4 pins as in powered state
    1- 18.2v
    2- 13.8v
    3- 2.4v
    4- 15.7v
    Any advices please. Thanks
  • hyditech
    • Jun 2012
    • 272
    • nigeria
    Re: HP G61 DA00P6MB6D0 no lcd backlight
    This are the voltage that make inverter works
    1- 18.5v
    2- 3.3v
    3- 3.3v
    4- GND
    • Cornito
      Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
      by Cornito
      Hello Team,
      I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
      Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
      Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
      08-08-2024, 08:09 AM
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
    • Comp_Pro
      No Backlight Macbook A1990 820-01041
      by Comp_Pro
      Hello all,
      Am trying to figure out this backlight issue with this A1990 Macbook Pro.
      Tests performed:
      There is no backlight even with a good screen.
      Backlight IC is receiving the correct support voltages.
      Fuse F8400 ok
      Current sense resistor R8400 ok
      Backlight IC is receiving 3.3V on enable pin.
      Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
      Backlight IC receiving 5V from PP5V_G3S
      Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
      I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
      05-06-2024, 10:23 PM
    • jimbofz
      lg 32LC46 backlight inverter board fault
      by jimbofz
      Hi this oldie had no backlight .after replacing caps on 24v rail ,
      still no b/l this uses inverter type:1315 B1-16A,
      im sure ive come across the same inverter in a samsung possibly le32r88bd ?
      all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
      this allows protect to be temporary overridden.
      b/l now comes on
      but the left hand side of pic is gradually darker than the right side
      i have the cct for the tv
      but it does not have inverter cct.
      i opened it up to inspect the ccfl tubes
      and they dont have any...
      12-19-2021, 06:58 AM
    • cheebster
      iPad Pro 12.9 5th Gen Backlight Issue
      by cheebster
      Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
      Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
      Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
      The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
      Anyone...
      05-20-2025, 09:17 AM
