K50IJ , have backlight but there is no image on it .
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Well i have this one on the bench , and have been cheking it and making my possible to make it working .
    it turn on a turn on backlight but there is no image on internal or externa, its the UMA version , only with the GL40 NB , tryed different screen and lvds conector , replaced rams , reballed the northbridge same effect, leaving it with only the memory soldered on board the same issue , reflashed bios all good .
    measured the lvds connector
    pins 1 2 and 3 - 3.3volts
    pins 25 26 27 and 28 - got 19 volts
    pins 29 and 30 - 3.3 volts
    so cheking schematic all voltages are present ,
    since backlight turns on i automatically assumed its not a onboard rams problems as well . only thinking in replacing NB , what are your opinions about .
    sincerely
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Re: K50IJ , have backlight but there is no image on it .
    replaced northrbidge all good , working as it should ,
    thk anyway
    • sparker1
      • Sep 2011
      • 343
      When to reball and when to replace? Is there any way to tell other than doing a reball first.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3573
        • slovakia
        when u have short on capacitors and coils to nb u MUST replace it. when no short just not work u can do reball
        • angel-boy
          • 550
          i have the same problem , light but no image, i dont have short capacitors in NB ,
          i must replace it ? ac82gl40
          • highpulse
            i hate HP
            • May 2013
            • 1488
            • portugal
            well , you can reball the chip , angel_boy is you do not find any caps in short.
            • Salem Aboshala
              820-00138-A got image but no backlight
              by Salem Aboshala
              Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
              I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
              History: my laptop backlight stopped working without any reason.
              Symptoms:
              I have image on screen using my flashlight.
              I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
              Keyboard backlight still working and can be adjusted normally.
              Since two days I tried to follow all similar...
              06-11-2024, 03:02 PM
            • zaurus81
              Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
              by zaurus81
              This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
              The board is equipped...
              01-16-2025, 03:54 AM
            • Constantinos
              Macbook Pro A2442 820-02098 No image but has backlight
              by Constantinos
              Hi all
              I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
              He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
              Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
              Obviously, he decided against this and gave it to me so that I could have a crack at it.
              From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
              08-24-2024, 09:48 AM
            • ajgae
              HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
              by ajgae
              Hi everyone!
              First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
              03-06-2025, 09:53 AM
            • learnmore
              Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
              by learnmore
              Hello Community!
              CASE DETAILS
              Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
              13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
              Tried inserting firmware on USB and left it in for a few hours, but no change
              03-03-2024, 09:49 AM
