HP 6730b - Southbridge with a hole in it!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Probably the first time i've seen anything like this on an Intel SB. Funny thing is that it isn't a dead short, it's around 2.5 ohms, and the power supply runs. 3.3v and 5v are present and have correct values, the other side of the board looks fine, and the only thing getting hot is the blown SB.
    I think it's worth attempting to replace it, i have a few of them lying around. Obviously, since they pretty much never die. Except for this one. I'm waiting for the OK from the owner regarding the price as he had someone else bring it in, then i'll be back with updates.
    A working TV? How boring!
  • c_hegge
    • Sep 2009
    • 5219
    Re: HP 6730b - Southbridge with a hole in it!
    Wow. I think I've only ever seen a cooked Intel SB on a desktop when the PSU (an Antec SP-350) failed and the 5vsb rail turned into the 12vsb rail.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      Got the OK, will get to it as soon as i get home.
      • dj_ricoh
        • 2073
        Samsung 2x r519
        One of them i burn .
        It made flames muhahhaha
        • 13mh13
          Aluminum SMD caps vs thru hole caps (reliability)
          by 13mh13
          The PCB motor for 1987 Technics SLP-120 CD player has slow spin-up issues. Similar to what another tech in the below video reported.
          https://i.postimg.cc/kGrR6BpZ/image.jpg
          I replaced the three bi-polar 47uF electros but that made no difference. The orig three bi-polar 47uF electros tested okay on my ESR M-tester.
          I have not tested/replaced those alum. SMD electro PCB caps.
          Are Al smd caps are more prone to failure (or degradation) than regular thru-hole electros?
          All the thru hole electros I removed / replaced on this CDP (and most...
          04-05-2024, 07:41 PM
        • Ruts
          PS5 EDM-033 Caps values near Southbridge
          by Ruts
          Hi
          I managed to knock off two capacitors on a EDM 033 board near the southbridge and BIOS chip.
          Does anyone know the values of these capacitors?
          09-15-2025, 06:00 AM
        • LearningToRepair
          How to correctly desolder through hole IC?
          by LearningToRepair
          Hi!
          I tried to desolder through I had IC that I wanted to replace but failed. And now I came here to learn what's the correct way for doing this. I tried to use soldering wick but the capillary force kept solder in the hole. With soldering wick I only managed to remove the part of solder that was outside the hole. But the solder that was inside the hole never got out. And of course when I moved on to next pin the solder in previous hole hardened again so no matter how many times I did all the pins there was still solder in holes.
          Question 1: what would have been correct...
          07-19-2020, 04:01 PM
        • bulkchart32
          i cannot get rid of the interference in the video on this 1.1v and i have tried everything!
          by bulkchart32
          i recapped the entire foxlink psu with rubycon caps of the exact uf needed. i also purchased a delta psu to see if the different brand would change anything and it did not. i recapped the entire motherboard except for about 5 of the 22uf caps. i used rubycon on everything except the five in front of the processors. i used 5 nichicon polymer caps there. i soldered a wire to each screw hole of the psu and soldered one wire to the metal outer shell and one to a screw hole on the motherboard(to make sure it was all grounded well). i also recently tried disconnecting the power cables from the dvd drive...
          06-19-2025, 02:37 AM
        • Hondaman
          Hardware firewall to block ad servers?
          by Hondaman
          I found an interesting summary on a wiki that Youtube "right to repair" enthusiast Louis Rossman put up. He suggested I could use a hardware firewall and pfSense as a firewall, and use pfSenseNG as an ad blocker. Or use OPNSense as a similar alternative. Seems like it would be easy to set up, but it only runs on the hardware supported by BSD. (I'm sure the developers and maintainers of BSD are super-busy and cannot support every single piece of hardware out there, so I can't fault them.)
          The trick, apparently, is to "assign IP address lists from sites like I-blocklist...
          02-05-2025, 05:04 AM
