imac with strange artifacts when turning on it
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    its a 20inches , a1224 imac , dual core , with MCP chipset only and cpu.
    what happens is that once i turn on , backlight is on , and see like pixel size dots everywere , after a while he get into windows , but we notice for sure , image is not correct or ok at all , but once i hibernate and than if i wake it up image is perfect ... once i shut down and turn on again , image is crazy again.
    what are you taughts ?
    thk in advance
  • lefos
    • Nov 2013
    • 321
    • Greece
    Re: imac with strange artifacts when turning on it
    My guess is on that chipset. Can you tell us its number?MCP...?
    • dellxps15
      • Feb 2014
      • 1591
      • italy
      it could be mcp67mv-a2
      • lefos
        • Nov 2013
        • 321
        • Greece
        My thoughts were on that too..If it is that one then change it to be sure
        • ryogadan78
          iMac A1418 - No LED, no power after overvoltage on Ethernet port
          by ryogadan78
          Hi guys, I need your help again.
          I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
          When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
          06-10-2025, 03:49 AM
        • Stephen
          iMac M1 DFU restore issue
          by Stephen
          iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
          this is the message it gives me with the error
          Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
          Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
          03-07-2025, 12:19 PM
        • Stephen
          iMac 27” 2020 Boot issue
          by Stephen
          Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
          08-16-2024, 09:32 AM
        • tommy97
          iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
          by tommy97
          we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
          Any ideas what might've...
          04-20-2024, 04:48 AM
        • mexbeb
          APPLE iMac (21.5‐inch, Late 2013) 820-3588-A not turning on, faulty PS?
          by mexbeb
          Ciao a tutti! I was given an old late 2013 iMac that doesn't turn on. I have the .brd file and the schematics and I've done a little analysis on the boards. Starting from the PS it appears to have 11.6V instead of 12V and that is a little strange, isn't it? Measured test points for PP12V_G3H and gives me 11.6V as well.
          The iMac have two different types of behaviour:
          1) no button pressed when inserting AC cable; inserting AC cable turns LED #1 on, when pressing power button LED #1 turns off for half a second, then turn on again, LED #2 turns on for half a second and...
          10-25-2020, 05:51 AM
