Dell N7110 does not see ODD and HDD
  • hazardus
    • Apr 2014
    • 105
    I've a Dell N7110 which does not see the ODD and HDD. I tried with different HDD and nothing. I tried a different bios nothing. I changed the HM67 chip and I've the same problem. I also changed the KBC.
    I tried with different CPU and ram but same problem.
    I've 3.3V and 5V at the SATA plug and I've also 5V at the ODD plug.
    I can see the communication at the SATA pins. What should I check?
    I'm totally lost here.
    Thanks.
  • dj_ricoh
    • 2073
    • uk
    Re: Dell N7110 does not see ODD and HDD
    does it see it in rack on usb>?
    • hazardus
      • Apr 2014
      • 105
      It sees the USB drives my portable SSD drive.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
        Dell Inspiron 17R N7110 Laptop Schematic
        Quanta V03A...
        11-01-2024, 03:06 PM
        Dell Inspiron 17R N7110 Laptop Schematic...
        10-11-2024, 06:34 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
