New Lenovo Thinkpad E540 Battery Problem
  • battery.12v
    • Dec 2014
    • 123
    • NW
    So i just bought my Lenovo Thinkpad E540 Before one month and suddenly when i'm working on it it shutdown so i tried to repower it but it fail , So i connect the AC adapter and it worked but windows started i found that my battery have a charge of 70% and it's status is "Not Charging" So i tried to disconnect my Ac Adapter and it shutdown suddenly .
    So in the end i want to know why my battery that's charged (i tested it's voltage and it was 11.5V) cannot power my laptop ???? (I do Not Try another Battery yet but i think the problem is not from my battery cause it's new)
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3575
    • slovakia
    Re: New Lenovo Thinkpad E540 Battery Problem
    u have warranty, so why u dont use it?
    • dj_ricoh
      • 2073
      • uk
      and never say its new (6 months )
      usually in europe warranty for a notebook its like this(IN CONTRACT)
      1 or 2 years and 6 months for the battery .(they say BYEEEEEEEEEEEEEEEEE)
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3575
        • slovakia
        NO! 6 month is for capacity, but 1 year is for work
        • battery.12v
          • Dec 2014
          • 123
          • NW
          hhhhhhhhh Warranty ???!!!
          I'm in War Sir, Here There's No Warranty In Syria !
          • dj_ricoh
            • 2073
            • uk
            Then update your country properly.
            • battery.12v
              • Dec 2014
              • 123
              • NW
              So there's no specific component which could be damaged ?
              Sorry but you are living in a country that have liberty and dimocracy here all our traffic is eavesdropped , so i must do like this
              • dj_ricoh
                • 2073
                • uk
                Open the notebook. Take the board out. Only connect the power button and install the battery.
                There must be something like this 3.3v on a few pins and if the battery its ... Lets say 10.8v
                On a pin there must be over 11v or near 12v to charge the battery.
                If you trace down that pin you will find a Fet and usually the gate does NOT open the fet that result in not charging the batt. If you trace the gate with continuity set on DMM you will reach the charging IC
                Do know i had the same problem a few weeks ago with a dv6 and c850 .
                Only saw battery not installed or plug in and NOT charging.
                After a while i found a good batt for both and now its charging.
                Change battery first. NO Compatible CHINES CRAP
                • battery.12v
                  • Dec 2014
                  • 123
                  • NW
                  It's a good guide, but if you could put to me the Motherboard Diagram it's a good thing cause i could not found it!
                  Thanx for help !
                  • GabrielS24
                    Lenovo E540 battery problem
                    by GabrielS24
                    Hello! I'm here to look for solutions to reset the EEPROM memory of a Lenovo E540 battery of 62Wh and 540mAh. I even bought a new one on the market (aftermarket BTIBM30) because I couldn't find an original one but it doesn't work. The laptop sees the percentage but blocks the battery charging probably because of the Chinese BMS. In the bios I don't have an option for the battery and I didn't find an older version (v1.57). I replaced the Lenovo BMS with Chinese cells but in windows it doesn't read the battery percentage and says it needs to be changed. I have 12v between D and the red wire....
                    04-16-2025, 05:23 AM
                  • NConstantinou
                    LENOVO YOGA 7 14ITLS 15 BATTERY REPLACEMENT PROBLEM
                    by NConstantinou
                    Dear all,
                    i have the above laptop which had a problem with battery. i replaced it with a compatible one..
                    the laptop DOES NOT POWER ON..
                    with it old battery it does power on.
                    i left the new battery disconnected and i powered on the laptop and i reconnected battery while laptop was on. it shows that the battery is charging.
                    when i shutdown the laptop does not power on.
                    does anyone have any solution!
                    when is not power on the usb c voltage tester shows 5v 1.3A
                    when i disconnect battery and power on and then connect battery the tester...
                    12-10-2024, 04:52 AM
                    Lenovo ThinkPad ThinkPad E15 Gen 2 (Intel) Notebook E Specification for Upgrade or Repair
                    This specification for the Lenovo ThinkPad ThinkPad E15 Gen 2 (Intel) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad E15 Gen 2 (Intel) boardview and ThinkPad E15 Gen 2 (Intel) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    09-07-2024, 05:00 AM
