Hp dv4 wsnu main board
  • dycc
    Vision
    • Nov 2011
    • 624
    • Côte d'Ivoire
    I am looking for high resolution picture of hp dv4 wsnu main board rev 2.1
    some components are missing on that board . If someone can help with pictures (dual side) , will really appreciate
  • chad720
    • Jan 2011
    • 16
    Re: Hp dv4 wsnu main board
    Hi, could you post the full model of that laptop? dv4-1225dx for example. And also, it would be usefull to have the model of that board you´r refering to.
    Thanks and good luck
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • JDC
      by JDC
      ONN 100012588
      Long answer:
      07-15-2022, 07:39 AM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • cheeky2
      by cheeky2
      05-25-2024, 03:27 AM
    • Asraf Atb
      Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
      by Asraf Atb
      Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
      Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
      I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
      01-27-2025, 05:02 PM
