something is wrong today
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    i have asus F5z that fires up only after heatedup so do a reflow and about 205c i hear puf and ic goes to short.
    next i wanna reflow ati GPU SB820 that not vanna showing picture so i heatid it to 195c to be sure it dont crack but after reflow it have one shorted power rail.
    it is so low temp that i canot understand why this happend. any help?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: something is wrong today
    Moisture trapped inside the chips. Try longer preheating times, 15-20 minutes at 120-150C.
    A working TV? How boring!
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      but will be board ok after that long heated time? aint be bending?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        If it's set nice and straight on the station, it will not bend.
        • Olvin1
          Acer nitro 5 an517-52 reflow/rebal CPU
          by Olvin1
          I’m kindly asking for help and advice regarding a reflow procedure for my laptop — Acer Nitro 5 AN517-52, which is equipped with an Intel Core i7-10750H processor.
          I own an ACHI IR 6500 infrared rework station and would greatly appreciate:
          • A detailed temperature profile for reflowing this specific CPU
          • Step-by-step guidance for a safe and effective reflow process
          • Tips on what to watch out for during the procedure
          If the reflow doesn’t resolve the issue, I’m also considering BGA reballing of...
          08-01-2025, 01:59 PM
        • tony359
          Reflow equipment
          by tony359
          Hello all,
          I am experimenting a bit with reflowing larger components - ideally I'd like to reflow a PS4 APU or a GPU for example.
          I know it's impossible to reflow such large components with just hot air so I bought a pre-heating plate, T-8280 classic Chinese machine, which seems to be working fine besides it's a little slow, which shouldn't be a big deal.
          Now, my hot air station is a Aoyue 852A++ and I feel it's a bit weak when used with larger nozzle. I tried reflowing a laptop chipset using one of those large, rectangular, nozzles and I failed miserably,...
          12-25-2021, 01:29 PM
        • Mr_Nada
          Concerns before attempting a Reflow of Laptop's GPU
          by Mr_Nada
          I saw some posts at one point talking about doing a reflow but I couldn't find them again so I thought that I would post this here.
          I plan on reflowing the GPU of this old HP DV2500 laptop but I want to go over what I have and the steps I have to take to guarantee it will come out fine.
          I have a Yihua 8786D 2in1 Rework station, flux (just some paste that I got from an old Radioshack kit), a couple rolls of Kapton tape and a $15 Thermometer +probe (a TM902C from EMR shielding Solutions if its important).
          • The paper that came with the thermometer states that the probe
          10-10-2024, 02:53 AM
        • jordi90
          Lenovo Thinkpad 20LT-S0KL1G bricked after writing the wrong eeprom
          by jordi90
          I was given a laptop with a BIOS locked by a password. I read that one way to unlock it is to read the EEPROM contents, patch them, and write them back. I was using the typical CH341A programmer and clip to do this, but because the clip is so loose, after patching the dump I accidentally placed the clip on the wrong EEPROM and now the laptop won’t boot.
          Can I do something to fix it? I’ve attached photos.
          10-09-2025, 01:08 PM
        • coinwizx
          Burned out PSU Corsiar HX1200 and NZXT C850, connected to wrong Molex/Sata cable from EVGA.
          by coinwizx
          Anybody has experience repair PSU burned out due to connect to EVGA molex/sata cables. I know the cable is not compatible (i got them mixed up), but I though i can connect it and use a PSU tested to find out which is the wrong sata/molex cables. As soo as I pluged in the powered molex cable to the PSU tester, the power supply short out, and will not turn on anymore. After the incident, the PSUs (both HX1200 and C850) try to power on and shut itself off immediately. The ATX PSU tester survice the short circult, still working perfectly. Anybody know if it's an easy fix or know which parts...
          09-09-2025, 03:11 PM
