Power Problem [can't resolve, plz help]
  • dspok
    • Jan 2014
    • 553
    • Nepal
    i had a dv6700 series laptop. i found pq3 brunt, changed it. now voltage on pl2 and pl3 comes 18v drops to 12v continuously. very low tik tik sound comes from somewhere which could not rectify and laptop doesn't turn on athough there is 3.3v on power button.
    charger ic pu1 is ok to confirm i have changed it, chaged sio same problem.
    pq61 has same voltage drop, also pin6 of battery connector has same problem.
    before laptop was turning on but battery won't charge.
    screwed up, please somebody help to solve the problem.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3607
    • slovakia
    Re: Power Problem [can't resolve, plz help]
    "now voltage on pl2 and pl3 comes 18v drops to 12v continuously"
    18V on battery, not good. bad charging voltage driving.. remove pq3 and check voltage
    • dspok
      • Jan 2014
      • 553
      • Nepal
      I checked after removing pq3, voltage is ok but laptop doesn't turn on. I suspect ACOK signal is bad but couldn't solve it.
      • dj_ricoh
        • 2073
        • uk
        find PL12 and PL14 and see if you got 3.3v and 5v
        • dj_ricoh
          • 2073
          • uk
          if your near that ISL ic PU10 post here the voltages
          • dspok
            • Jan 2014
            • 553
            • Nepal
            Can find 3.3v and 5v but i will post pu10 voltage later. Thanks in advance.
            • dj_ricoh
              • 2073
              • uk
              its this with AMD cpu?
              • dspok
                • Jan 2014
                • 553
                • Nepal
                No it is intel. 5v and 3.3v also drops to 4.2v and 2.2v following tik tik sound.
                • dspok
                  • Jan 2014
                  • 553
                  • Nepal
                  As 5v and 3.3v was droping, i changed isl chip. Now 5vpcu is ground, don't know from where this voltage linked. All 5vpcu is ground. Please suggest.
                  • Ramee
                    • Jul 2014
                    • 218
                    • Israel
                    You are asking for help, but dj_ricoh asked you to write down the PU10 voltages, but you did not do it.
                    • dspok
                      • Jan 2014
                      • 553
                      • Nepal
                      @Rame
                      I understand dj_ricoh asked for PU10 voltage but I followed stupid idea to change it, which caused 5VPCU circuit to ground.
                      • Ramee
                        • Jul 2014
                        • 218
                        • Israel
                        redo redo!
                        • dj_ricoh
                          • 2073
                          • uk
                          Originally posted by dspok
                          @Rame
                          try to resolder it!
                          maybe bad contact or some flux
                          • dspok
                            • Jan 2014
                            • 553
                            • Nepal
                            Thanks dj_ricoh but i think I have more problem now. Even I remove PU10 there is still ground at PL14.
                            PL5, PL6 also ground where as PU8 is ok. Pin 1,2,3 on PQ61 ground too. Looks like my bad idea fried mb.
                            • dj_ricoh
                              • 2073
                              • uk
                              ok lift pl14 pl5,6 and see where is the short
                              to IC or other side
                              • dspok
                                • Jan 2014
                                • 553
                                • Nepal
                                It is to the other side.
                                • dj_ricoh
                                  • 2073
                                  • uk
                                  on every coil?
                                  do you have a lab PSU?
                                  • highpulse
                                    i hate HP
                                    • May 2013
                                    • 1488
                                    • portugal
                                    my friend the tik tik noise come from a bad FET , also chek for components above the cpu socket usually they have a black tape on it , there is a component responsable for the acok sign that will make the charger ic drive the 24 volts for the gate of the main Powermosfet this component is on the right sde of the PC195 IC with 6 legs.. is a very common fault on this laptop .personally fixed a few , also chek for PD17 and Q40 and reading schematic pin 6 of schematic should be giving you lt least 18.8 volts , also as PD17 on both sides
                                    • highpulse
                                      i hate HP
                                      • May 2013
                                      • 1488
                                      • portugal
                                      now for the 5 volts line coil , so very probably when you were messing with 19 volts line , you damaged the the mosfets on that line . chek mosfet if bad on board , remove and test outside , and with mosfet lifted , chek for GND on coil.
                                      if problem persist , lift one leg of the coil and chek wich side is shorting to gnd , and read schematic after this . to chek the main component until +5va out , if all seems fine , then start injecting 2 volts and start increasing slowly , always chek amperage comsuption ,and to help you out , start cheking for heat points on the board , after you find it , just spray a bit of IPA to make sure of the exact component that is getting hot , , any help just ask mate
                                      • dj_ricoh
                                        • 2073
                                        • uk
                                        Originally posted by highpulse
                                        Just spray a bit of IPA to make sure of the exact component that is getting hot
                                        o that`s so freaking Cool! cuz IPA does not drive the current! freaking GENIUS!
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • Duranitron
                                          Asus x512dk rev 2.1 power on problem
                                          by Duranitron
                                          When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                                          Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                                          11-26-2024, 10:22 PM
                                        • EazyBone
                                          LG OLED55C9PUA power problem
                                          by EazyBone
                                          Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                                          Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                                          I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                                          The power supply to t con is different story.
                                          This...
                                          06-23-2023, 07:43 AM
                                        • Dr.d
                                          Help please..Lenovo ideapad 5 14itl05 power and charging problem
                                          by Dr.d
                                          I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                                          Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                                          04-05-2024, 11:48 AM
                                          03-31-2024, 02:12 PM
