Acer Aspire E1-531
  • Senior Eng
    • Nov 2014
    • 10
    • Iraq
    Acer Aspire E1-531
    the laptop is not turn on then I found PL1 is missing i brought new one it worked but it still show no display and turn of after a few seconds ... the voltage that's go to battery is 2v ... help me with this plz guys and show me the process for general lap repair.
  • Senior Eng
    • Nov 2014
    • 10
    • Iraq
    Re: Acer Aspire E1-531
    Basic steps please ....
    • cyberhack
      • Feb 2013
      • 466
      • Uk
      Your knowledge ie can you use meter read diagrams
      • Senior Eng
        • Nov 2014
        • 10
        • Iraq
        of course cyberhack ... i need to know where are the voltage reading points ... the voltage for charging battery ... CPU voltage and where to check it
        thanks.
        • dj_ricoh
          • 2073
          thanks.
          yee yeee!
          Basic POST :
          Motherboard Model
          Motherboard picture
          what did you check ?
          • Senior Eng
            • Nov 2014
            • 10
            • Iraq
            Originally posted by dj_ricoh
            Motherboard Model
            Motherboard picture
            ََQ5WV1 LA-7912P
            there was no voltage ... I found PL1 was missing so there is voltage now.
            I ask you what to check!
            thanks for reply
            • dj_ricoh
              • 2073
              pictures! high Q
              on page 45 right side bottom you got a list of Jumpers PJ1 - > PJ19 find every jumper and post back the voltages
              • Senior Eng
                • Nov 2014
                • 10
                • Iraq
                pj1 3v
                pj2 5v
                pj3 18
                pj4 0v
                pj5 0v
                pj6 0v
                pj7 0v
                pj8 0v
                pj9 0v
                pj10
                pj11 0v
                j11 2v
                pj12
                pj13 0v
                pj14 2v
                pj15 2v
                pj16
                pj17
                pj18
                pj19 0v
                • dj_ricoh
                  • 2073
                  oii you got basic stuff!
                  change/reprogram bios and change bios battery!
                  do you know how to do reflow?
                  • Senior Eng
                    • Nov 2014
                    • 10
                    • Iraq
                    What to reflow ... BGA????
                    do I need programmer machine for reprogramming bios or just from DOS???
                    thanks alot.
                    • Ramee
                      • Jul 2014
                      • 218
                      • Israel
                      You need machine for reflow/reball
                      http://www.aliexpress.com/item/Scotl...712640472.html
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3580
                        • slovakia
                        or a 200W halogen light for 6eur, multimeter with thermo probe and a piece of bold paper on top
                        i was using it when i start to work on BGA. confirm it work without any problems.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          can you explaine a bit more about this set up? have you got pictures of it in use.
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3580
                            • slovakia
                            i dig out some old pictures.
                            i dont recommend using higher walues of lamp. 200W is fairly good enought to not damage the board or components on it. even chip is less heated than with station so it is safe for ati igp that like to die in 220+ celsius.
                            i see it on youtube video from some it guy from russia. he repaired almost everything with very shitty tools
                            • Senior Eng
                              • Nov 2014
                              • 10
                              • Iraq
                              Guys .. I found pc102 cap is shorted ... maybe it is the problem ??
                              • dj_ricoh
                                • 2073
                                you have to take it down!
                                after check the pads then the capacitor!
                                • Senior Eng
                                  • Nov 2014
                                  • 10
                                  • Iraq
                                  what you mean?
                                  • dj_ricoh
                                    • 2073
                                    when you check a capacitor ON the board and its got a short, the capacitor can be good but there is a short in that line with ground!
                                    so take it down and see if the pads where capacitor is are shorted or just the capacitor.
                                    • Senior Eng
                                      • Nov 2014
                                      • 10
                                      • Iraq
                                      I removed the cap ... the pads still reading 0.01 ohm ""shorted"" .... also PL14 reading short on board .... what to do ??
                                      • ktmmotocross
                                        Boardkiller
                                        • Feb 2014
                                        • 3580
                                        • slovakia
                                        remove pl14 and check which side is shorted
                                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:30 PM
                                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                          ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
