HP Presario CQ50, AMD, power sequence Required
  • sanehdeep2012
    • Oct 2013
    • 139
    • india
    HELLO FRIENDS,
    received one HP Presario CQ50 AMD astrospher MCP laptop,
    when pressing Power button LED2(charging led blink three time and goes off, during blinking of led,
    L14=3.36V
    L15=5.11V
    L6=0.66V(Without battery)
    L13=0.00 All the Time
    L1=0.00V
    VCORE=0.00 (all The time)
    L3=0.00V (
    L4=0.00V
    U54= Replaced No change
    PIN 14, 15 OF U54 =5.1V during led flashing when power button press and then goes low 0.00v
    PIN 10,11 OF U54 alway low no change during power up and power button press.
    any help on this regards is appreciable
    i will be very thank full to you,,
    please give me Power Sequence of CQ50 if any body have,
    schematic and bios bin i have
    bios already update.to new working bin
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3641
    • slovakia
    Re: HP Presario CQ50, AMD, power sequence Required
    in schematic there is mcp67 an on bios u have mcp77
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3641
      • slovakia
      check resistance of that coils
      also check KBC_PWR_BTN# and PWRBTN#_MCP
      • dj_ricoh
        • 2073
        how much amps it drains with battery when its off?
        did you reflow?
        • sanehdeep2012
          • Oct 2013
          • 139
          • india
          thanks for replay to my post and giving your valuable time me,
          i will check and revert back soon
          thanks
          • sanehdeep2012
            • Oct 2013
            • 139
            • india
            i have mcp77, same schematic isl with me sorry for early msp67
            • sanehdeep2012
              • Oct 2013
              • 139
              • india
              KBC_PWR_BTN# pin is working ok it goes low during power button press, as i say power goes up when pressing powerbutton, with three time flashing of power led power goes off, during this power on process
              only
              L14=3.36V
              L15=5.11V
              is having voltage other then that no coil having any voltage,
              • sanehdeep2012
                • Oct 2013
                • 139
                • india
                did you reflow?
                i have not reflow till now,
                battery already i have removed , mb out saide laptop now,
                • sanehdeep2012
                  • Oct 2013
                  • 139
                  • india
                  dear friends I am back again ,
                  i was found that resistance of L4 to ground is 4.9E
                  so i replace NVidia CHip MCP77MV-A2 Replaced,
                  but again it is same low resistance,
                  kindly help as i found same:
                  L14=3.36V
                  L15=5.11V
                  L1=0.00V
                  L3=0.00V (
                  L4=0.00V
                  • sanehdeep2012
                    • Oct 2013
                    • 139
                    • india
                    pl help and share the power sequence of attatchment model:
                    my model is CQ50, AMD ,NVIDIA MCP77MV-A2
                    astrosphere_MCP mb 07241 3 , 48.4J103.031
                    • sanehdeep2012
                      • Oct 2013
                      • 139
                      • india
                      pl any body help
                      • Compute
                        Master
                        • Oct 2014
                        • 97
                        • Russia
                        Motherboard Wistron Astrosphere?
                        I need model motherboard for help you
                        • Compute
                          Master
                          • Oct 2014
                          • 97
                          • Russia
                          already seen ...
                          Let me see if I have
                          • Compute
                            Master
                            • Oct 2014
                            • 97
                            • Russia
                            Schematics, Boardview & Power Sequence
                            • Compute
                              Master
                              • Oct 2014
                              • 97
                              • Russia
                              4.9E
                              4.9 Ohm?
                              • sanehdeep2012
                                • Oct 2013
                                • 139
                                • india
                                sorry master /compute sir , due to some person issues I was unable to see the replies you have send, thanks for your kind attention.
                                I will check and revert soon, dear thanks again
                                • sanehdeep2012
                                  • Oct 2013
                                  • 139
                                  • india
                                  thanks I was searching these things only. thanks may I need you help dear compute
                                  • sanehdeep2012
                                    • Oct 2013
                                    • 139
                                    • india
                                    KBC_PWR_BTN# is ok
                                    PWRBTN#_MCP is ok
                                    PM_SLP_S5# is missing no voltage at that point when pressing power button
                                    • dj_ricoh
                                      • 2073
                                      My friend.
                                      3 blinks its memory.
                                      2nd it could be CPU to.
                                      3rd check voltage near memory socket.
                                      • sanehdeep2012
                                        • Oct 2013
                                        • 139
                                        • india
                                        no voltage to memory
                                        cpu check with replacing with new one
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • Andreas_de
                                          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                          by Andreas_de
                                          Hello!
                                          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                          04-12-2025, 10:38 AM
                                        • claws77
                                          lenovo flex 5 14itl05 power sequence issue
                                          by claws77
                                          hi guys, my motherboard will not start no matter what
                                          when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                          but rest nothing happens no sign of life.
                                          this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                          with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                          but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                          i have no knowledge of motherboards ....
                                          10-20-2024, 02:48 PM
