rare AT6 dv600 board lots of issues , remaining a last one :P
  • highpulse
    i hate HP
    • May 2013
    • 1489
    • portugal
    well this board entered the store yesterday , just today i had time to open it , symptom not turning on or charging bat . opened it and visually nothing seems burned . so start main test , were 19 volts goes . max until source of pq52 , and pin1 of system charger . ok , injected 19 volts with source lab to see if i found a short after that PQ52 , but nothing . all seems fine , started t chek coil to GND found te 5 volts line shorted , PC111 was dead , replaced it , 5 volts line no more n short . since i chekd that the gate of PQ52 was still 19 volts , simply there was no ACOK signal to the gate of the transitor that will make that gate to drop to 0 or negative allowing the 19 volts to pass all over the circuit . so replaced system charger after replacing system charger somehow PD22 got damaged , not allowing pin1 of system charger to receive power , replaced pd22 and all good , cheked coils , 5 and 3.3 on . i turn on machine , it turns on , but turn off . in that isntance i can measure very quickly the S0 of major coils , telling me they are giving correct values . for exception of PL22 PL23 does dont give me any values , but cheking them , got pl22 180ohm , pl23 22.5 ohm , compairing to outher board i got here , same ohmic value , so not a possible short on the 1.05 line .
    im gonna now test S3 and S5 states n the KB , if all good im out of ideas.
    any tought are welcome
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: rare AT6 dv600 board lots of issues , remaining a last one :P
    test all switched power rails and when all ok check the powergood logic
    • highpulse
      i hate HP
      • May 2013
      • 1489
      • portugal
      well cheking for KBC issue , and signal are beeing sent when pressing on , and the signal it should be receiving it is receiving , only signal not sent by KBC when pressing on off switch is the ECPWROK
      • u666sa
        HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
        by u666sa
        Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
        Platform: ipa32 la-m024p rev 1b
        Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
        I found a short on the other side:
        10-04-2025, 05:03 PM
      • supermattch
        HP 15dy-2021nr wont power on mystery volts
        by supermattch
        Hi everyone.
        I am diagnosing my personal laptop, because it wont power on and no leds light up.
        At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
        Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
        09-23-2025, 12:13 PM
      • MisterAIL
        PS5 digital / No Power / No Beep / Good power supply
        by MisterAIL
        Brought a non functionnal PS5. Apparently only a bad PSU...
        No beep, nothing.
        After some tests i found this :
        - PSU is fine (12 volts stable)
        - 12 volts line is shorted
        - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
        - By the way, nothing change. No signal, no power, no beep.
        Mesuring all rails with my workbench psu (12 volts input)
        - 0.00 amp drawing
        - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
        03-12-2024, 03:24 PM
      • Mcfeetroy
        Fishing bite alarm drains battery
        by Mcfeetroy
        Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
        08-01-2025, 03:52 AM
      • BTubbs200
        Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
        by BTubbs200
        Dell Latitude 5420 P137G
        Board: LA-K491P REV A01
        I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
        Board seems to have no shorts, all power rails are fine and show high resistance.
        When charger is plugged in, voltage is present in 3.3V rail but absent in others....
        01-24-2025, 08:15 PM
