neo b1230
  • rickybucalan
    • May 2013
    • 322
    • philippines
    neo b1230
    good day guys. i got neo b1230 that has power but only white display appears on screen.
    anyone could give me schematic diagram for this. thanks in advance..
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: neo b1230
    If you can connect an external monitor - does that work?
    • dj_ricoh
      • 2073
      • uk
      Re: neo b1230
      usually it works.
      i saw 3 days ago with i3 and no ventilation on the chipset(not req)
      change the cable screen and still the same.
      next week i`ll go for a new cpu and a chipset!
      Try the same if the cable and screen did not fix it
      • rickybucalan
        • May 2013
        • 322
        • philippines
        Re: neo b1230
        it does not work with external monitor
        i try to change lcd it show white screen also. i check cable its fine no cut wires.
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • ipatch
          ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
          by ipatch
          i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
          08-24-2024, 02:36 PM
        • FreakyMex
          Trouble to identify part (Lunii screen) for replacement
          by FreakyMex
          Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
          I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
          02-17-2025, 01:16 AM
        • jean luc ferre
          laptop hp g72 b52sf screen problems
          by jean luc ferre
          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
          06-07-2025, 03:27 PM
