Pliable Thermal Heat Sink Adhesive
  • Ltank
    • Jun 2013
    • 776
    I can find heat sink compound, epoxy but what I need is. A pliable heat sink adhesive that will hold a heat sink to a IC in a vertical position. Needs to be pliable to be removed or replaced when service is required. I found just about everything but what I need. Any suggestions or links?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Pliable Thermal Heat Sink Adhesive
    Sorry if my suggestion doesn't fit your need, first off
    Now, why not get a bunch of these and just replace them? Exactly how often do you need to redo it? How heavy is the heatsink?
    http://www.amazon.com/StarTech-com-H...ustomerReviews
    Would something like that work? As you can most people in the reviews that gave it a bad rating simply don't understand how it works!
    another option might be something like this, but you'd probably have to apply it each time:
    http://www.amazon.com/Arctic-Alumina...ustomerReviews
      Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
      The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
      Securing a good thermal interface between...
      10-07-2024, 04:35 AM
    • eccerr0r
      Heat sink modding... thermal mass vs surface area?
      by eccerr0r
      Well, my Gateway monitor seems to eat caps. So I was thinking there was some systemic issue going on here and what I'm thinking: the heatsink is blocking convection flow and thus roasts capacitors by radiation!
      Now what I wonder. This piece of aluminum heatsink is obviously blocking convective flow. I could add a fan but there are some other issues involved here. How about...drilling holes into the aluminum?
      The holes would add surface area and allow air to convectively flow through the heatsink which could reduce temperatures. However this would of course reduce the...
      04-15-2022, 10:25 AM
    • Veyron7887
      Laptop overheating after replacement thermal paste
      by Veyron7887
      Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
      11-24-2024, 05:08 AM
    • Gcnewbie
      Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
      by Gcnewbie
      Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
      I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
      My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
      I opened the...
      03-29-2024, 06:55 AM
    • resistor83
      Hp Pavilion 15-ab062nl gets hot and shutdown in some situation
      by resistor83
      hello everyone, I have a HP Pavilion 15-ab062nl laptop with a complete shutdown problem
      I state that the problem is neither the SSD disk (new) nor the ram that I changed with various modules.
      A few days ago I formatted this laptop with windows 11 and during the installation (more or less from 30% to 50%) the laptop shuts down completely. Keeping the laptop open I notice that the copper heat sink is quite hot and therefore I change thermal paste with an artic MX-4
      I try again to format and now the laptop turns off but towards 60 70%. I leave it all night to...
      03-04-2023, 10:12 AM
