this laptop won't charge any battery, but charger led in on, windows shows plug in charging, but the percentage remains the same. Need urgent help.
					Toshiba Satellite L450D charging issue
 Re: Toshiba Satellite L450D charging issue
 Got this from a site
 To check the power supply status, install a battery pack and connect an AC adaptor.
 Check 1 If the DC IN LED blinks orange, go to Procedure 2.
 Check 2 If the DC IN LED does not light, go to Procedure 3.
 Check 3 If the battery LED does not light orange or green, go to Procedure 4.
 Procedure 2 Error Code Check
 If the power supply microprocessor detects a malfunction, the DC IN LED blinks orange.
 The blink pattern indicates an error as shown below.
 Start Off for 2 seconds
 Error code (8 bit)
 “1” On for one second
 “0” On for half second
 Interval between data bits Off for half second
 The error code begins with the least significant digit.
 Example: Error code 12h (Error codes are given in hexadecimal format.)
 <----------Read
 0 1 0 0 1 0 0 0
 Start Bit 0 1 2 3 4 5 6 7
 Order -------->
 Check 1 Convert the DC IN LED blink pattern into the hexadecimal error code and
 compare it to the tables below.
 DC IN
 Error code Meaning
 10h AC Adaptor output voltage is over 16.5V.
 11h 10/100 Network Port Replicator II or Enhanced Port Replicator II
 12h Current from the DC power supply is over the limit (6.16A).
 13h Current from the DC power supply is over the limit (0.5A) when there is
 no load.
 14h Current sensing IC is not normal.
 Main Battery
 Error code Meaning
 20h Main battery voltage is over 13.46V. (Not supported)
 21h Main battery charge current is over 5.06A.
 22h Main battery discharge current over 0.5A.
 23h Main battery charge current is over 2.70A.
 24h Current sensing IC is not normal.
 25h Main battery charge current is over 0.3A when there is no charging.
 Secondary Battery
 Error code Meaning
 30h Secondary battery voltage is over 13.46V.
 31h Secondary battery charge current is over 5.06A .
 32h Main battery discharge current over 0.5A.
 33h Secondary battery charge current is over 2.70A.
 34h Current sensing IC is not normal.
 35h Secondary battery charge current is over 0.3A when there is no
 charging.
 S5V output
 Error code Meaning
 40h S3V voltage is under or equal to 3.14V.
 EVER5V output
 Error code Meaning
 50h EVER5V voltage is over 6.0V.
 51h EVER5V voltage is under or equal to 4.5V when the computer is
 powered on.
 52h EVER5V voltage is under or equal to 4.5V when the computer is
 booting up.
 53h EVER5V voltage is abnormal when the computer is suspended.
 EVER3V output
 Error code Meaning
 60h EVER3V voltage is over 3.96V.
 61h EVER3V voltage is under or equal to 2.81V when the computer is
 powered on.
 62h EVER3V voltage is under or equal to 2.81V when the computer is
 booting up.
 63h EVER3V voltage is abnormal when the computer is suspended.
 PCOREV output
 Error code Meaning
 70h PCOREV voltage is over 2.04V.
 71h PCOREV voltage is under or equal to 1.08V when the computer is
 powered on.
 72h PCOREV voltage is under or equal to 1.08V when the computer is
 booting up.
 73h PCOREV voltage is over or equal to 1.08V when the computer is
 powered off.
 PGTLV output
 Error code Meaning
 80h PGTLV voltage is over 1.725V.
 81h PGTLV voltage is under or equal to 1.275V when the computer is
 powered on.
 82h PGTLV voltage is under or equal to 1.275V when the computer is
 booting up.
 83h PGTLV voltage is over or equal to 1.275V when the computer is
 powered off.
 B1R8V output
 Error code Meaning
 90h B1R8V voltage is over 2.16V when the computer is powered on.
 91h B1R8V voltage is under or equal to 1.53V when the computer is
 powered on.
 92h B1R8V voltage is under or equal to 1.53V when the computer is
 booting up.
 93h B1R8V voltage is abnormal when the computer is suspended.
 BVGAV output
 Error code Meaning
 A0h BVGAV voltage is over 2.28V when the computer is powered on.
 A1h BVGAV voltage is under or equal to 1.53V when the computer is
 powered on.
 A2h BVGAV voltage is under or equal to 1.53V when the computer is
 booting up.
 A3h BVGAV voltage is abnormal when the computer is suspended or over
 1.53V when the computer is powered off.
			Toshiba Satellite L450D Laptop Schematic
 Compal LA-5831P Ver 1.0...-
							Channel: Schematics and Boardviews
 11-01-2024, 02:28 PM
 COMPAL LA-5831P...-
 11-01-2024, 04:46 AM
			i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
 VCCIO voltage ok
 VCCSA Voltage OK
 VCCPLL Voltage OK
 Ram Voltage ok
 RamVTT OK
 VPP 2.5 OK
 But No Core Voltage
 and i want to this vrm ic datasheet or pinout (ISL69269)
 anyone have this ic pinout voltages?...
			by electron_jjHi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
 I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
			by sam_sam_samI found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
 The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
 Now...
- Loading...
