apple a1260 m88
  • guruji
    • Oct 2012
    • 122
    • India
    apple a1260 m88
    hello i have a macbook 17" the graphic was short and the 1.8v line short i replaced the graphic and one mosfet which now the laptop powers on but does not detec ram it give me no ram beep which ever ram i use. all power planes are ok which signal do i check for ram ddr2 detect.
  • techman1025
    • Jun 2014
    • 497
    Re: apple a1260 m88
    Hi Dead N/B any time graphic has been shorted it kills the N/B heat it to 100C see if it come alive yes ..then replace N/B
    Techman1025
    • a_p3rson
      Apple Watch Charging Controller Schematics / Boardview - 820-02601
      by a_p3rson
      Hi there,
      I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
      You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
      This daughterboard uses an interesting...
      04-21-2025, 11:41 PM
    • DynaxSC
      Extreme High Current & Low Voltage Short Killer ??
      by DynaxSC
      Hi Folks
      I'm looking for a extreme high current short killer solution for a reasonable cost.
      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
      After taking off the socket, the shorts dissappear again.
      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
      10-15-2024, 10:13 AM
    • Guest
      A noob needs help for Apple Macbook Air M1 2020 A2337 - logic board short circuit
      by Guest
      Hello all!
      Recently I've got a broken Macbook Air M1 2020 A2337 of eBay with a broken screen and not turning on issue.
      After some tinkering I've found C5201 capacitor to be blown. This is where I hit a wall since I am a total noob in this area and have no idea what else to look for. C5201 is on one line with 3 more capacitors which visually seem ok, but beep on continuity mode and also both sides of all capacitors beep when tested with ground from the board. This to me sounds like a short, but I am not able to find what component is before the capacitors to test it....
      09-26-2024, 03:31 AM
    • Stephen
      MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
      by Stephen
      I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
      02-06-2025, 12:03 PM
    • adelfr2009
      HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
      by adelfr2009
      I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
      After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
      09-28-2025, 10:21 PM
