hp compaq no power
  • o0Jigsaw0o
    • Jul 2014
    • 11
    • Philippines
    hp compaq no power
    Hello, Good day to all! I'm new on repairing laptops. I have a hp compaq laptop here without power when I switch on. I found one of the fet not having any output voltage. Two capacitors and one resistor. Is it ok if I replace those components? Hope you can guide me troubleshooting this problem. I'm just a newbie here. Thanks!
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Re: hp compaq no power
    find schematic, then make some repair
    • dj_ricoh
      • 2073
      when you say HP COMPAQ no power nobody can help.
      model of the notebook( if its HP look under the battery and write it here ex:cq-XXXzz)
      you need schematic (find the code on the mainboard need post it here)
      with model we can provide a bios image so you can reflash the bios, ofc you need a bios programmer.
      many more thinks but you can start with those.
      model and board Number
      • o0Jigsaw0o
        • Jul 2014
        • 11
        • Philippines
        Sorry about the info. It's Hp compaq presario cq61
        BOARD MODEL
        DA00P6MB6D0
        PCB OP6 MB
        REV: D
        (6L, 234 2X205)
        • justice171
          Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
          by justice171
          I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
          Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
          1. Verified that all critical voltages are present:
            • 3.3V and 5V are always present if DC is plugged.
            • 1.8V on the BIOS chip is present.
          2. Checked the power button functionality:
            • When pressed, the voltage drops to 0V, indicating the button is functional.
          3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
            • Confirmed connectivity is intact, ruling out issues
          11-26-2024, 12:39 AM
          by sam_sam_sam
          03-31-2024, 02:12 PM
        • dragon3x
          >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
          by dragon3x
          Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
          that is still quite new, as it worked OK for some months until it failed.
          At the time I was not into power supply electronics; it was put
          aside and a new power supply installed inside the computer. Also at the time
          power supplies were half the price of today's.
          On the PCB there are a D339 and 7500B chips.
          I have found that schematics with these 2 chips (see included file).
          Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
          Some measurements,...
          06-05-2024, 03:34 PM
        • Zippie
          Troubleshooting Old Chiefmax 650Watt ATX Switching Power Supply
          by Zippie
          I’m looking for some advice troubleshooting an old Chiefmax 650w power supply in a PC, if it’s advisable to dig into it.
          Worst case I can replace the PSU, I’m just interested in learning the troubleshooting process. However, it’s out of my area of expertise and I could use some direction.
          During PC operation I heard a loud pop noise, like a cap gun and the tower lost power.
          Initially there is no power output 3.3v, 5v, or 12v when jumping the power on pin to ground. Also, no fan power.
          Opening the PSU the only things visible initially...
          03-07-2024, 07:58 PM
        • ipatch
          troubleshooting microsoft surface pro 4 no power no led charge light
          by ipatch
          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
          10-05-2023, 11:59 AM
