Is it ok installing a Type-C adapter on a laptop when the charger controller IC is removed? I am repairing a laptop with a burned charger controller IC, and after replacing it with a new IC, it burned again. I want to check the voltage on the ics pin without the Type-C controller IC soldered
Is it ok installing a Type-C without Controller IC?
by master3112I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on... -
by mikey5791Hi to all forum members,
Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor... -
by ronnygraciasThe treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...4 Photos
by corrizeHello, I start to repair this sort of board, but I’m lost. Bye the old 2 mosfets + charging chip + 3v-5v…
I can’t « read » this board (Asus UX425 but I saw this in others boards).
I see :
In GREEN : 2 diodes for 2 power USB-C ways (I removed one diode)
BLUE : 2 thunderbolt controllers
RED : PD controller CYPD (for negociate the voltage with devices plugged in USB-C)
Comment : in order to appearence, I see thunderbolt controller « and after » PD controller guess. I guess (I hope) those 2 controllers are in parallele, for separate power and signal...-
Today, 04:30 PM -
by sam_sam_samThis happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
I am comparing them to a brand new one that I installed
The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
I going to let it run for several days before I remount back on the wall next to the... - Loading...
