Resistor value identification
  • hopkok
    • Oct 2014
    • 184
    • Slovakia
    Hi guys, what is the resistor value of R7201? Not sure.
    Thank you
  • hopkok
    • Oct 2014
    • 184
    • Slovakia
    Can it be 1,78Mohms?
    • mon2
      • Dec 2019
      • 14791
      No. The '1' is a bad cad to pdf conversion sideband issue.
      Which exact model are you reviewing? Which motherboard? The shared screen does not display the required details.
      • hopkok
        • Oct 2014
        • 184
        • Slovakia
        Hi mon2, LENOVO Thinkpad P1 Gen2 - Wistron 18809-1, schematic attached. R7201 position, marked as "1D78MR2F-GP".
        Thank you
        • mon2
          • Dec 2019
          • 14791
          Page #2 has a resistor part decoding scheme posted. Suggest to hunt for other schematics with the Think Engine part to compare this value. Will review later.
          • reformatt
            • Feb 2020
            • 1546
            Nice find. Never noticed that before, thought it was a manufacturer part number or something. So the D probably stands for decimal. So....
            1.78Meg 0402 1% tolerance
            • hopkok
              • Oct 2014
              • 184
              • Slovakia
              I decoded it for 1,78Mohms too...
              • bumper1
                Razer Blade 15 RZ09-0328 DA550-MB - resistor identification
                by bumper1
                I have Razer Blade 15 RZ09-0328 MOBO: DA550-MB MP V4.0 20200227 with liquid damage.
                I need to know value of resistor on photo. Thanks for help. ...
                07-10-2025, 03:34 AM
              • jinu_j
                by jinu_j
                Hi
                05-03-2025, 10:51 PM
              • GottaBeGrim
                PNY RTX 3060 12GB single fan resistor identification
                by GottaBeGrim
                hello, i have the gpu in the title and a resistor fell off that i need help finding the resistance of. does anyone have the schematic or the resistance value? see images below for the one missing....
                01-02-2025, 08:11 PM
              • mikey5791
                Need help to replace burned resistor in 350w atx psu
                by mikey5791
                Hi to all forum members,
                Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                12-26-2024, 04:55 AM
              • redbaron1007
                Klein MM400 resistor identification
                by redbaron1007
                I managed to blow the fuses in my Klein MM400 multimeter and when I replaced them I was still getting a cal and error0 message. I started looking around the board and found one resistor that was testing OL and has a visible burn mark on the top of it so I can't tell what the value is anymore. Its marked as R19 on the board and I included a picture below of what it looks like.
                Does anyone know from working on these what the value is or have this exact meter they could open up and check the value? It's not my only meter, but it is my first real non harbor freight meter...
                07-24-2024, 03:53 PM
