HP LA-G07JP only power but with battery but charges powered off
  • alsupo
    Good afternoom, my HP laptop with board Compal LA-G07JP only starts with battery but with something anormal :
    - With only battery startup is normal.
    - With only AC adapter same voltages but no EC_ON, no power up.
    - Powered off AC adapter charges battery normally.
    - With AC adapter charging battery as soon power on is pressed, charge is interrupted and laptop begins to run from battery.
    No way to run from AC adapter. Which can be the reason?
  • mon2
    • Dec 2019
    • 14727
    Review the dual diode @ PDB1. Remove all power. Meter in DIODE mode. Test this diode.
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • bykanovm
      Thinkpad W541 Works from the mains and charges the battery only when it is turned off
      by bykanovm
      Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
      If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
      If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
      even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
      Also, the laptop does not turn on without...
      04-02-2025, 02:45 AM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • huzo
      HP ELITE X2 1013 G3 weird battery issue
      by huzo
      Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
      01-31-2025, 12:09 AM
      ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
      Highly Integrated Narrow VDC Battery Charger for Notebook Computers
      The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
      for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
      Narrow VDC applications where the system power source is
      either the battery pack or the regulated output of the charger.
      This makes the max voltage to the system equal to the max
      battery voltage instead of the max adapter voltage. Operating
      at lower system voltage can improve...
      11-05-2024, 04:43 PM
