HTC One M7 Mainboard
  • Harley_B
    • Sep 2014
    • 6
    wondering if anyone here can give me some advice on fixing a lifted pad on my HTC one m7 smartphone? I don't have much area to play with in regards to adding a new trace, I have attached some pics of my problem, and I'm hoping someone can give me some good advice? I don't have schematics of the phone, so if anyone knows anything about the screens Fpc connector pin-out, that would be a bonus?
    Thanks for reading
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3578
    • slovakia
    Re: HTC One M7 Mainboard
    no problem. just scratch the green layer and solder a wire as a pad
    • Harley_B
      • Sep 2014
      • 6
      Thanks for reply, but I'm not sure If I can? There seems to be a dark spot in the middle,Is this another layer? The area is so small to scratch, this image is @20x magnification?
      Any ideas welcome?
      • Harley_B
        • Sep 2014
        • 6
        Here's another image at 380x magnification
        • xxxvirus1987xxx
          unlegendary
          • Sep 2014
          • 24
          • philippines
          just clean it using 99% alcohol or lacquer thinner to see it clearly...
          then just scratch the the green layer you can do it..
          • bohaboha
            ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
            by bohaboha
            Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
            04-19-2025, 01:47 PM
          • stylishconsultant
            un60j620dafxza - Samsung No Display Problem
            by stylishconsultant
            Hi All,
            Need help.
            I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
            So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
            problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
            might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
            09-04-2024, 03:26 AM
          • Mirenia
            Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
            by Mirenia
            I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
            I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
            In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
            The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
            03-30-2025, 06:47 AM
          • orcic
            MASTER TL240 and new mainboard LW36BKC01
            by orcic
            I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
            The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
            After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
            Now I have some doubts about how to connect the new mainboard to the old power supply.
            First of...
            05-12-2023, 08:10 AM
          • praveenramavath
            Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
            by praveenramavath
            Hello All,
            I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
            https://www.hifivision.com/threads/m...-screen.98243/
            Troubleshooting Summary: Majority Internet Radio - Flash Chip
            04-26-2025, 09:08 AM
