ASUS 5538G no power at all
  • rippergr
    • May 2014
    • 345
    • Ελλάδα
    Hello all,
    I have an asus 5538G laptop which doesnt power on.
    I test the ac adaptor and the power jack , I have power to the connector of the power jack.
    Can someone tell me how can I dig deeper?
    I found the diagram which is here
    https://www.badcaps.net/forum/attach...4&d=1385748314 Thanks to Francisco.s
    I think I have to start from the power voard page 35 but I don't know how to start.
    If someone can give me directions to start.
    Thanks in advance.
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Re: ASUS 5538G no power at all
    i think its acer aspire 5538G not an asus, please upload schematic or motherboard model name, to help you;
    • rippergr
      • May 2014
      • 345
      • Ελλάδα
      Yes you are right. it is ACER and not ASUS
      I have the link of the schematics in my first post.
      and here is another link to schematics.
      http://adf.ly/6548800/https://mega.c...TBnfVaPT57HY8I
      • polytek
        • Dec 2013
        • 496
        • TUNISIA
        check the B++ of tps51125 see the picture attached;
        and then check if pl4 have 3.3V and PL5 have 5V
        • rippergr
          • May 2014
          • 345
          • Ελλάδα
          I measure it with power only (the laptop doesn't start anyway)
          pin 16 of tps51125 no voltage.
          pl4 no voltage
          pl5 no voltage
          Do I have to press the power button or just to connect the power adaptor?
          • polytek
            • Dec 2013
            • 496
            • TUNISIA
            just when you plug the power adaptor you should mesure this voltage.
            • polytek
              • Dec 2013
              • 496
              • TUNISIA
              check between PQ7 and PQ8 you should find 19V if there is no voltage try to change PQ7 (4407)
              • rippergr
                • May 2014
                • 345
                • Ελλάδα
                on PQ7 I have in all pins 19,30V
                in PQ8 I have 19,30 V in pins 1,2,3,4 and 0V on 5,6,7,8
                • fddizon
                  • Sep 2011
                  • 555
                  • Philippines
                  if all pins in PQ7 are 19v, PQ7 maybe shorted.
                  check without battery and ac adapter, with ohm meter if source and drain is short.
                  replace if shorted.
                  if PQ7 gate voltage is high, 5 6 7 8 pins should have 0 volts
                  • rippergr
                    • May 2014
                    • 345
                    • Ελλάδα
                    replace if shorted.
                    I think you are right. I measure PQ7 with multimeter in diode mode and pin 1,2,3 (which according to datasheet http://aosmd.com/pdfs/datasheet/ao4407.pdf are source)
                    and pin 5,6,7,8 (which are ground) all measure .000 both ways(I. is infinitive in my multimeter)
                    in PQ8 it measure only in one way .
                    So I suppose I must first change PQ7.
                    • atsio
                      • Oct 2013
                      • 819
                      • Greece
                      Remove it and check it of the circuit.
                      • rippergr
                        • May 2014
                        • 345
                        • Ελλάδα
                        Hmmmmm I think I broke it :p
                        I am waiting for a new one.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5076
                          • New Zealand
                          If it broke in half that easily it was probably blown anyway
                          -David VanHorn
                          • rippergr
                            • May 2014
                            • 345
                            • Ελλάδα
                            I change the mosfet with a new one but still no the laptop doesnt power on. Any idea?
                            • fddizon
                              • Sep 2011
                              • 555
                              • Philippines
                              ripper,
                              you should check voltage signal again bro.
                              drain, source and gate voltage...
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5076
                                • New Zealand
                                Yeah, could be the gate drive circuitry also failed
                                -David VanHorn
                                • rippergr
                                  • May 2014
                                  • 345
                                  • Ελλάδα
                                  Ok the problem now was that the ac jack was a little out.
                                  It's ok now. Everything working fine.
                                  It was the mosfet PQ7 that was blown away.
                                  Thanks everyone for your help.
                                  • GLISIT
                                    by GLISIT
                                    01-16-2025, 02:29 PM
                                  • PantherDave
                                    by PantherDave
                                    Hi all!
                                    05-29-2024, 02:01 PM
                                  • ShadowAi
                                    ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                    by ShadowAi
                                    Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                    Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                    After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                    03-15-2024, 10:46 AM
                                  • meraklinetx
                                    Asus Z97-a power cycle, no boot no cpu voltage
                                    by meraklinetx
                                    Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                    05-10-2023, 06:08 AM
