Lenovo Air 15ITL NM-D211 missing RSMRST !
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Lenovo Air 15ITL.
    NM-D211
    This laptop won't power on , when power supply is on it takes 0.001 , button trigger on it becomes after a couple of seconds 0.061 amp..and nothing
    No heating (Of COURSE) , no short to GNd at all coils present , 3/5 valw is present , 3/5 vl present.
    With the power plane , at state 4 +1.8VALW and +3ALW_PCH must be present but no one due to enable signal is missing .
    when button trigger on , 3v dow to zero than 3v , the super io send BTN_OUT#_R to pch but no rsmrst ..0v.
    i follow his line , no short .
    Try a virgion bios UC702 + UC703 fron here no change
    this is the io requirements ..( if i miss some voltage please tell me )
    +3VL_EC_R present.
    VCC_FSPI present
    VCC_LPC_ESPI is present
    WRST# is peresent
    VCORE 1.8v present
    ON/OFF present
    BUT no EC_RSMRST#..
    All rtc section is OK ( i find some corrision at CC1002 and clean it )
    my io programmer didn't support this io..
    Can we conclude , since my charger section / power section /rtc section/ bios are good that my issue is the bios inside io or the io himself !!
    OR is there a differents others steps to confirm before !
    Thank you
    Schematic+BoardViewer : https://www.badcaps.net/forum/troubl...wer#post102439
  • Fernon@Repair
    MSI mpg b560m bazooka motherboard RSMRST# signal missing
    by Fernon@Repair
    I have MSI mpg b560m bazooka motherboard . this motherboard RSMRST# signal missing . i already reprogram bios but same condition
    My Motherboard this power stages are ok ...but 3vsb voltage have 4.17v (image added)
    VCCRTC ok
    RTCRST# ok
    ATX_5VSB ok
    SIO_3VA ok
    3VDSW ok
    DPWROK ok
    SLP_SUS# ok
    VSB_ENABLE# ok
    5VDUAL ok
    3VSB showing 4.17V
    PCH_1P8_VSB ok
    PCH_VCCIN_AUX ok
    RSMRST# No voltage
    this all voltages are ok but RSMRST# voltage is missing i did try to re program bios and change io but same...
    06-03-2025, 10:49 AM
  • Lucifer87
    rx 5700 pulse Schematic & Boardview request 1.8 missing sometimes present
    by Lucifer87
    Hi, I need the schematic and boardview of a Radeon RX 5700 Pulse, sometimes it turns on, sometimes it doesn't... I checked when it doesn't turn on, the enable signal is missing on pin 15 EN2 3v to power 1.8v... the problem is that when it works I can't test it since the signal is present... I would like to check the signal paths but I would need the diagram and the boardview thanks​...
    12-15-2024, 12:29 PM
  • Kooopa
    Acer Nitro 5 EC_RSMRST# present, Missing SLP_S5#!!!
    by Kooopa
    Hi! I'm diagnosing my Nitro 5 AN515-43 Mobo: FH50Q LA-J621P. I left it on sleep mode but when I came back It won't turn on. Power LED would turn on for a few seconds then off. no fan spin nor keyboard backlight.
    So I tried the usual procedures first, power cycling and bios reset but non did the trick so I decided to delve deeper.
    Nothing strikes as red flags aside from the dust. there's no history of any liquid being poured at it since I bought the thing, I've been real careful. Anyways.
    I checked the usual rails +5VALW +3VALW even the 1.8VALW and 0.9VALW...
    09-06-2024, 11:38 AM
  • Swell61
    Gigabyte X570 Aorus Pro rev1.0 diagnostics
    by Swell61
    Hello
    I have a Gigabyte X570 Aorus Pro rev1.0 that doesn't work. I know the motherboard is at fault because the CPU, RAM and power supply have all been tested with a known good motherboard (including after trying them in the faulty board to check it hadn't killed them).
    Thanks to some people on this website and elsewhere on the internet, I have a schematic and boardview for the WiFi version of this board, a schematic for the Elite version of this board (same board but cut down on features) and repair guides for other AM4 boards, one of which is for an Asus Tuf Gaming...
    11-07-2023, 03:32 AM
  • Prott
    Surface 7 - missing S3 sleep signal, S4 present but weird
    by Prott
    Hey fellow Badcappers
    I am troubleshooting Surface 7 board (rev 1.0) which was working great until it experienced a short circuit due to a bad screen.
    Now it's missing SLP_S3 signal. Everything in the power on sequence works properly up until that signal.
    - The resistance to ground on the SLP_S3 line is >50 kOhms.
    - No shorts on any powerrails that I can find.
    - I get a proper clock signal on the RTC crystal (XTAL_2P) once the Surface gets power.
    - SLP_S4 is, suprisingly, present, but it looks very weird (jump up to 2 V for about...
    07-08-2023, 04:54 PM
