LA-L191P cpu resistance (+VCCIN)
  • reassor
    • Apr 2021
    • 181
    • Poland
    Im used to do basic resistance meassurements around main IC's just to see whats the condition. But here i see 110 OHM on coils relative to GND. Is that normal with these CPUs?
    Laptop turns on stays at 0.05A and shuts down. Charging works. 1.8v, 5v and 3.3V present.
    CPU = i5-11400H
    Thx in advance for clearing that up for me
  • guyandpit
    • Oct 2021
    • 85
    • Philippines
    for 11th gen thats normal, try to check the vccin_aux resistance and also check other voltage, pch and sio if getting hot.
    • reassor
      • Apr 2021
      • 181
      • Poland
      Aux has around 400ohm.
      Tbh nothng gets hot at 0.05A but u given me hope on the cpu part. Ill take a deeper looksie.
      Thx
      • reassor
        • Apr 2021
        • 181
        • Poland
        PCH kinda gets hot and its VDDCIN_AUX_PCH is 1.8v. There is no EC_RSMRST# pull down an i got all basic voltages (3.3v , 5v, 1.8v) but nothing that turns on after ec and pch.
        • reassor
          • Apr 2021
          • 181
          • Poland
          VCCIN_AUX_PCH 500 ohm?
          • reassor
            • Apr 2021
            • 181
            • Poland
            Also no slp_s3# and slp_s4#
            last voltage that appears is EC_RSMRST# (3.3v). Im looking at power startup sequence.
            Thought bios but no change. It even acts same w/o bios chip (silly test but still did it)
            • cind12
              GTX 1080 TI Gigabyte Aorus low resistance on vmem
              by cind12
              Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
              Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
              The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
              Resistance on 12V 4K ohms (Power present when on)
              Resistance on 12V PEX 4K ohms...
              12-08-2023, 09:09 AM
            • Nagy Daniel
              Lowest possible resistance on laptop motherboard rail - Guide Table request
              by Nagy Daniel
              Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
              I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
              I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
              So, I generated a table with AI so I can...
              03-04-2025, 08:24 AM
            • Jane
              What is the lowest acceptable resistance on a coil without considering a short on PCB
              by Jane
              I have Asus FA506 ( board DA0BKXMB8D0 Rev: D). Can you please roughly indicate what the lowest resistance I should measure on a coil? I know that a low resistance is allowed on coils in CPU or graphic circuits but can you provide acceptable values of resistance?
              Thank you.
              02-27-2024, 01:42 PM
            • loopster
              645 G9 with Ryzen 5 PRO 5675U | Resistance to ground of CPU?
              by loopster
              Hello everyone, I have a 645 G9 here with a Ryzen 5 PRO 5675U.
              This board has a blown inductor component above the driver chip to the CPU coil, and I am wondering whether the CPU is shorted/dead.
              Could anyone please measure the resistance to ground on the leftmost coil/inductor to the CPU?
              My resistance value is 2.2 Ohms, which doesn't look good to me.
              Thanks to everyone willing to give a value.​
              06-05-2025, 02:33 PM
            • CG2
              Janome DC3050 Sewing Machine Pedal Resistance
              by CG2
              OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
              Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
              04-14-2023, 07:53 AM
