Acer Aspire 5750 no B+ voltage
  • ahmetozay
    • Jul 2013
    • 73
    • turkey
    Hi, i have 19v on pq7 but only 1v output thus no 3.3v nor 5.0 v always voltages and the system is dead at the moment. in the attachment i measured the voltages at start of the B+ rail. Any advices welcome
    Motherboard model is P5WE0 LA-6901P REV 2.0
  • multiplexer
    • Dec 2012
    • 30
    • italy
    Re: Acer Aspire 5750 no B+ voltage
    Measure the voltages on pins 1, 2, 8, 23, 24 of PU1
    Measure the voltages on all the pins of PQ14
    • ahmetozay
      • Jul 2013
      • 73
      • turkey
      Thanks for the reply
      pu1
      1=5.1v
      2=1.35v
      8=0v
      23=0
      24=18.5v
      PQ14
      1=0v
      2=0v
      3=0v
      4=0v
      5=0v
      6=6.1v
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3553
        • slovakia
        u must have short to ground on B+ rail
        remove all PJP and check which powerrail is shorted
        • ahmetozay
          • Jul 2013
          • 73
          • turkey
          i thought of that and shorted the pin 1 and 8 of PQ7 but there was no short. But after your message i tried to short 1 and 8 pin of pq7 but this time with 19v and the motherboard worked ok. Thus i changed the pq7 with the new one but still output is 1v, very strange
          • multiplexer
            • Dec 2012
            • 30
            • italy
            Measure the voltages on all the pins of PQ19
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3553
              • slovakia
              check resistance to ground on pin 5-8 on pq7
              • ahmetozay
                • Jul 2013
                • 73
                • turkey
                PQ19
                1=2.6v
                2=0v
                3=ground
                • ahmetozay
                  • Jul 2013
                  • 73
                  • turkey
                  Resistance is reading in mega ohms so definetely no short
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3553
                    • slovakia
                    did u use exactly the 4407?
                    • ahmetozay
                      • Jul 2013
                      • 73
                      • turkey
                      it was 4459 and i used 4435 instead
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3553
                        • slovakia
                        on your picture it is 4407
                        but 4459 can handle TRIPLE current than 4435 so u probably burn that 4435
                        • ahmetozay
                          • Jul 2013
                          • 73
                          • turkey
                          this board is rev 2.0 4407 is in the rev 0.1
                          • ahmetozay
                            • Jul 2013
                            • 73
                            • turkey
                            no its not burnt still output is 1v
                            • atsio
                              • Oct 2013
                              • 819
                              • Greece
                              pu1
                              1=5.1v
                              2=1.35v
                              8=0v
                              23=0
                              24=18.5v
                              PQ14
                              1=0v
                              2=0v
                              3=0v
                              4=0v
                              5=0v
                              6=6.1v
                              You have 19v and acset voltage to the charger but not acprn signal. Replace charger ic. I always replace and the fets, so I suggest replace and pq15 and pq16
                              • ahmetozay
                                • Jul 2013
                                • 73
                                • turkey
                                changed charger ic but there was no difference. so charging i is ok. any other advice?
                                • multiplexer
                                  • Dec 2012
                                  • 30
                                  • italy
                                  Measures PQ19 taken according to this numbering?
                                  See Annex
                                  Voltages do not add up
                                  Considering the numbering as an attachment
                                  PQ19 pin 1 connected to pin 23 of PU1 (0V correctly stated)
                                  pin3 PQ19 (must essera to about 3V) connected to pins 2, 5 PQ14 (0V incorrectly stated)
                                  Pin 2 to ground PQ19
                                  Check that the pin 2 of 3 PQ19 are not short.
                                  • atsio
                                    • Oct 2013
                                    • 819
                                    • Greece
                                    I posted without reading ISL's datasheet. ACPRN should be low.
                                    What is the voltage on pin 4 of PQ6 and PQ7? What is the voltage on pins of PQ14?
                                    • multiplexer
                                      • Dec 2012
                                      • 30
                                      • italy
                                      See attached first post
                                      pu1
                                      1=5.1v
                                      2=1.35v
                                      8=0v
                                      23=0
                                      24=18.5v
                                      PQ14
                                      1=0v
                                      2=0v
                                      3=0v
                                      4=0v
                                      5=0v
                                      6=6.1v
                                      Here are the steps required
                                      • ahmetozay
                                        • Jul 2013
                                        • 73
                                        • turkey
                                        See Annex
                                        i've checked PQ19 but only 1 pin is shorted to groun other pins are not shorted
                                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:30 PM
                                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                          ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
