K40IN getting hot on the nvrams
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Ok , so i received this motherboard to fix , and found a few issues on it , it was with a shorted mosfet attached to one of does 51117 TPS , sincerely its a shit board since nothing is identified , but for my experience this is for lower voltage , rams or gpu or MCP in this case.
    SO replaced mosfet , and machine turn on , get heat on the mcp and Vcore for ir , but 0 volts for CPUcore .
    SO replaced this 51117 on that line , seems some values were not beeing sent from it , (for what i can see on schematic , so after replacing it , i notice the Vrams get hot when i turn it on , (when turning it on previously green light stay on , but no vcore . ) now led shut down after few secod , but still having Vcore on cpu 1.09 volts , and cpu still hot , but also the 4 nvram stay hot .(bottom of the RAM socket) (the guy who gave me this mentioned this was happening and now image ... so beeing around this board by intuition is a bit lamme and critical , since we must travel around Tpoint (only ID i got to be more near of wich part of the schematic im testing. if anyone had this issue before on the same or simillar machine , share some info .
    thk in advance
    BTW the coil of that TPS 51117 for the VRams , one side on S5 gives me 1.54 volts but the outher side gives me 1.77 volts ( i assume is gettig hot the nvrams due to this , will replace this coil just in case ..
  • dj_ricoh
    • 2073
    • uk
    Re: K40IN getting hot on the nvrams
    believe me when I tell you that ppl LIE ALOT.
    I have here on the forum a novatech or something like that I try to power it up and it had the connector fk up and it shorted something ram got hot and rest nothing. change the ram unplug the bios battery and connected the board to dc jack and it power up normal. after I shutdown from power button I cant turn it on ; I got to do the same procedure battery out 5 sec off the plug the charger. it power up auto .
    try and if this happens something bad happen to the board like my display board(he try to change the screen with battery with notebook on or sleep with everything connected dc and batt on)
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      hey mate was sup , well this guys i trust (i know what they do ) when its a client then i don't believe the fairytale they tell me .but this guys want me to solve problems they can't or don't find a way of solving it . and what is getting hot is the four nvrams usually found on the outer side of the board one side is were the ram socket is , and the outer side is some soldered nvrams to it (seems the nvrams for the MCP chipset. does are the ones that get hot . in the previous post i mentioned about strange coil giving 1.77 , but its suposed since its a 1.8 volts line. now really don't get the idea of why they get hot when pressing the ON button , and then the green led shutdown , but still having 1.5 line and Vcore line and cpu still getting hot . but what annoys me more is the fact of this dam board not having ID on the components.... and its a pain in the ass finding a good board view program as also a good board view for the correct board !
      ok rechecking now , does chip under the ram socket are onboard DRAM .
      btw my board as mentioned its a K40IN rev 2.2
      • dj_ricoh
        • 2073
        • uk
        can you make a list of every QFN chip you got on the board?
        and the KBC chip.
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          KBC is ITE8500E AX0
          QFN chips
          ISL6262 cpuvcore
          mb39a132 (seems main regulator)
          3x 51117
          tpa6017
          one realtek for LAN and aother realtek for Audio
          • highpulse
            i hate HP
            • May 2013
            • 1488
            • portugal
            really getting tired now , of this motherboard , without ID's , getting hard to find the culprit here
            • MisterAIL
              PS5 digital / No Power / No Beep / Good power supply
              by MisterAIL
              Brought a non functionnal PS5. Apparently only a bad PSU...
              No beep, nothing.
              After some tests i found this :
              - PSU is fine (12 volts stable)
              - 12 volts line is shorted
              - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
              - By the way, nothing change. No signal, no power, no beep.
              Mesuring all rails with my workbench psu (12 volts input)
              - 0.00 amp drawing
              - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
              03-12-2024, 03:24 PM
            • Mcfeetroy
              Fishing bite alarm drains battery
              by Mcfeetroy
              Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
              08-01-2025, 03:52 AM
            • BTubbs200
              Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
              by BTubbs200
              Dell Latitude 5420 P137G
              Board: LA-K491P REV A01
              I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
              Board seems to have no shorts, all power rails are fine and show high resistance.
              When charger is plugged in, voltage is present in 3.3V rail but absent in others....
              01-24-2025, 08:15 PM
              MPJA 10 AMP @ 0 to 30 Volts Switching Power Supply Cap Fault
              I have this 10 amp 0 to 30 volt switching power supply that decided to have a 630 milliamperes draw on it at 0 volts
              I open it up to find non brands name capacitors in it
              I am not sure how this switching power supply is set up
              Could someone please explain how this power supply works
              Here is the capacitor ESR results
              (1) 47uf@50 volts 0.46
              (2) 47uf@50 volts 0.45
              New 47uf@50 volts 0.35
              (1) 100uf@25 volts 0.34
              (2) 100uf@25 volts 0.35
              New 120uf@50 volts 0.08
              (1) 220@25 volts 0.13...
              10-21-2018, 10:02 AM
            • Superbee_dad
              Sharp 80” long short flash backlight error - Help
              by Superbee_dad
              Hello Sharp TV experts
              Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
              > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
              > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
              01-24-2025, 11:51 PM
