CQ42 Power Problem , Pls Help
  • nazrul145
    • Jan 2014
    • 337
    • BD
    Hello brother, I need help for cq42 power problem. its 5v 3v not present, Because there is no 19v in PR159. I have checked PQ47 Pin 1 gate is 6v so that pin 3 has only 6v. Now i cant find why pq47 pin 1 gate is low. Please help me How can troublshoot it.
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Re: CQ42 Power Problem , Pls Help
    have you check if there 19V at PD14 cathode pin if no 19V:
    check the cap: pc67, pc142, pc151, and PD14 if shorted remove all from the mobo
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • Gibon378
      Problem with stopping audio and video for no reason
      by Gibon378
      PC Specs:
      • CPU: Ryzen 5 1600
      • GPU: GTX 1080 Palit JetStream
      • MOBO: ASRock ab350 PRO4
      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
      • PSU: XFX 650W (don't remember what model)
      • OS SSD: ADATA SP920
      • OS: Windows 10 21H2
      Problem description:
      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
      11-19-2022, 09:41 AM
    • perzyk23
      Lenovo T580 - LCD Panel problem - error 0288
      by perzyk23
      Good morning,
      I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
      10-25-2024, 12:42 AM
    • lazaro.089
      Asus Zephyrus M16 / GU603ZW problem
      by lazaro.089
      Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
      CPU: Core i9-12900H
      Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
      Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
      The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
      08-26-2025, 06:33 PM
    • SDNarcia
      Dell 15R-5521 keyboard problem (KBC?)
      by SDNarcia
      Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
      As additional information,...
      07-20-2024, 10:47 PM
