Dell 1545 - No Power
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Hello, I have really a new problem today on Dell 1545.
    --Problem--
    Machine turns on & instantly turns off.
    Removed RAM - Turns on continuously.
    I suspect there is a problem in GMCH or BIOS but not sure.
    So, please help if anybody has solution for this issue.
    Also please upload BIOS.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Dell 1545 - No Power
    --Problem--
    Lets narrow the problem down...
    Its it with one stick of ram or others ?
    • dspok
      • Jan 2014
      • 553
      • Nepal
      @ReeceyBurger123
      Problem is with both RAM including new working RAM
      • dspok
        • Jan 2014
        • 553
        • Nepal
        --double post--
        • dspok
          • Jan 2014
          • 553
          • Nepal
          anybody please....
          • polytek
            • Dec 2013
            • 496
            • TUNISIA
            this is the rom bios:
            • hoarderteks_kyriakos
              Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
              by hoarderteks_kyriakos
              Hello.
              Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
              Here is what happened:
              At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
              10-08-2025, 07:33 AM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • reessi
              HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
              by reessi
              I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
              It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
              What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
              I have checked these lines in diode mode and they seam normal -> 600.
              I have checked to see if they come on for even a fraction of a second...
              07-15-2025, 09:14 AM
            • Mark01
              Dell Optiplex 7490 AIO - red power led after flash
              by Mark01
              Hi guys,
              This is my first post! 🚀
              I have no idea what I’m doing, but I’m learning by trial and error.
              I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
              07-04-2025, 12:54 PM
            • LimesKey
              Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
              by LimesKey
              Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
              10-17-2025, 05:33 PM
