MacBook Pro M4 Pro - no keyboard / trackpad / lid sensor
  • mitchw
    • Dec 2016
    • 151
    • Slovenia
    Hello
    I got this MacBook Pro M4 Pro to have a look at.
    It was tiny bit liquid damaged, just the edge of the board got 1 small 10x10 mm area wet. I've seen much worse that still worked fine to be honest.
    Since it was liquid damaged, warranty does not apply anymore.
    Anyways it was checked at an local Apple Store and they discovered that it needs new trackpad, new top case, etc. Also it needed a new lid angle sensor which they replaced.
    The main issue was that the screen remained black.
    Anyways I cleaned the liquid damaged area, put the machine back together and I noticed this:
    - Internal keyboard not working. However I can turn on the machine with pressing any of the keys.
    - Trackpad also dead
    - Machine will not sleep / turn off LCD, when lid is closed
    So now I am thinking the whole issue might be just with the Lid Angle Sensor which they replaced at an Apple Store but they might forgot to calibrate.
    Or there might also be an issue with the trackpad which I discovered was sitting bit uneven, and when I took it off, 3 out of 4 metal shims were missing! One of them was lodged beneath one of the trackpad springs. I am guessing the technician removed this trackpad to check for the liquid damage, and since there was none, he just put it back, but lost the shims.
    Or perhaps this is indeed a Logic Board issue. Sadly I can't find the schematics for it. I compared it to the M3 MBP14 board, but they are quite different.
  • mon2
    • Dec 2019
    • 14631
    Review this:
    https://www.youtube.com/watch?v=u18D...hannel=AhaTron
    • mitchw
      • Dec 2016
      • 151
      • Slovenia
      Thanks. I checked it out. On their machine the sensor is working, but not at the right angle.
      Mine is completely dead, it does not register opening/closing it no matter the angle.
      Which is weird as it was just replaced. I could try moving the magnet by 180 degrees, but I am thinking that the lid sensor is not even initialized (programmed). I read somewhere that new Lid Angle Sensor needs to be initialized, otherwise it will not work at all.
      What about the non-working trackpad / keyboard?
      I guess I should replace the trackpad first?
      • mitchw
        • Dec 2016
        • 151
        • Slovenia
        Also forgot to add, but running the diagnostics throw following errors:
        NDR008 NDK001
        • mon2
          • Dec 2019
          • 14631
          https://discussions.apple.com/thread...06?sortBy=rank
          check your keyboard cable.
          • mitchw
            • Dec 2016
            • 151
            • Slovenia
            Originally posted by mon2
            Ok!
            I checked. Keyboard and trackpad cables are both fine.
            • mitchw
              • Dec 2016
              • 151
              • Slovenia
              I replaced the trackpad with a new original Apple part and it is still not working :/
              I still have to replace the angle lid sensor but I am not sure if will cause the trackpad/keyboard not to be functional
              I am bit lost on this one.
              • mitchw
                • Dec 2016
                • 151
                • Slovenia
                I decided to check SPI and I found the computer does not detect any SPI devices (it should detect trackpad and keyboard).
                Next I again remeasured the Lid Angle Sensor voltages and found 2 voltages missing:
                - SPI_AOP_LAS_MOSI_1V8 (0V)
                - SPI_AOP_LAS_MISO_1V8_R (0V)
                Other voltages are present, as well as SPI_AOP_LAS_CLK_1V8 which is at 1.8V
                As the schematics are not available I can't trace them.
                • mitchw
                  • Dec 2016
                  • 151
                  • Slovenia
                  I made some progress, I updated to the latest MacOS 26 Tahoe and it immediately prompted me to calibrate the Lid Angle Sensor. I did the configuration and now the Lid Angle Sensor is working. So apparently it was fine, just not calibrated.
                  But trackpad/keyboard are still not functional. Diagnostics say that the trackpad is not compatible with this model, despite being the right one. So I am guessing there might be more SPI problems. I perhaps could try doing the DFU restore, but the last time I tried, it failed due to trackpad being not connected (it was, but not detected)...
                  • mon2
                    • Dec 2019
                    • 14631
                    Hunt for and validate any level shifters that should be present between this trackpad and the main bus master (PCH).
                    • mitchw
                      • Dec 2016
                      • 151
                      • Slovenia
                      Will do. From what I've seen the level shifters for the keyboard/trackpad SPI are mostly the same on M3 MacBook Pro 14.
                      Anyways I managed to "brick" the system, I tried doing the DFU and it failed mid process. Now I only get the dreaded exclamation mark.
                      I tried to do the DFU multiple times and from 2 different machines, both fail with same error: (7) 130C.FFFF
                      My guess is that this means that it failed because of the missing trackpad. Interestingly it also failed before, but almost at the beginning, so it didn't do anything. Last messages in the updater log suggest that it failed to update firmware of one device, most likely trackpad.
                      Most likely it wasn't detecting the lid sensor and therefore it failed.
                      So note to myself (and others): next time, don't do a DFU if the machine is booting into the OS!
                      • fajfelek
                        Macbook Pro M1 a2338 after liquid damage - Need help with identify missing part on trackpad logic board
                        by fajfelek
                        Hello, First of all thanks you for reading this topic.
                        I need your help with identify missing parts on trackpad logic board (661-18430).
                        The liquid got into the orange area, but I found that the green area had some parts missing or burnt.
                        Please help me with identity parts from blue and red area .
                        06-15-2024, 01:41 PM
                      • No Lan
                        [Macbook pro A1708] [Boot loop] [Trackpad ?]
                        by No Lan
                        Hey everyone,
                        Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                        Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                        Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                        05-24-2025, 03:09 PM
                      • Skrndelj
                        Apple Macbook Air M1 A2337 Trackpad problem
                        by Skrndelj
                        Hello all,
                        I am repairing a Macbook A2337 and i have a problem
                        The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
                        When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
                        I inspected the whole board and everything seems fine.
                        Can anyone help me as i didn't fiddle with trackpad...
                        06-11-2024, 04:26 AM
                      • rynr
                        MacBook Air M2 A2681 no Trackpad
                        by rynr
                        I have been following the posts in the forum for some time now and have learned a lot. I would first like to thank you for this and hope that it will continue for a long time.
                        I received the MacBook in DFU. The recovery always failed with error 1. After some search, I was able to find a defective inductor (LT202).
                        After replacing the component, I was able to successfully complete the DFU restore. Unfortunately, the trackpad and keyboard where still without function.
                        So i measured all voltages and diodereadings on the JT400 connector. ...
                        11-04-2024, 09:56 AM
                      • spidertnt
                        820-02443 14" M1 angle sensor / keyboard / trackpad not working
                        by spidertnt
                        FYI.
                        I just had a 14" M1 MacBook Pro with liquid damage very small pretty much only angle sensor sustained any corrosion or damage.
                        But both keyboard and trackpad will not work at all ! Screen would flicker on and off all the time.
                        I ended up re-building the traces on the angle sensor cable using very small copper wire... this fixed both the flickering and the keyboard / trackpad.
                        I'm like WTF does the angle sensor have to do with keyboard / trackpad ?
                        04-29-2023, 11:03 AM
