Lenovo E15 - NM-E211 doesnt turn on
  • Gokhant
    • Aug 2025
    • 10
    • Danmark
    Im trying troubleshoot a Lenovo E15 which is not turning on.
    Charging Led is ON when charger plugged in.
    PC doesnt turn on when pressing on button.
    Sometimes on button blink 3 times and shut off and repeat it sometime again.
    I took the motherboard out , and connected my in-line dc-meter and it shows 20.16V and 0.00A which for me sounds correct as there are nothing connected , not even battery.
    With everything connected to the motherboard, in-line-dc-meter shows 20.09V and current consumption of 2.1Amps.
    In-line dc-meter restarts like once in every minut.
    PQ4000 is warmer then the rest ,you can easily hold your finger on without burn.
    QB5 and QB6 has 20.02V in and out.
    J5 shows 5.14V
    Any advice on how i should proceed with this?
  • Gokhant
    • Aug 2025
    • 10
    • Danmark
    Here are som measurements
    • mon2
      • Dec 2019
      • 14662
      QB5 may be in trouble. The reason being that the gate voltage is almost the same voltage as the source / drain voltages.
      If the mosfet is a P-channel type, the voltage should not pass through since the gate voltage is not low enough to enable the mosfet.
      If the mosfet is an N-channel type, the voltage should not pass through since the gate voltage is not boosted enough over the 20v on the source / drain pins to enable.
      The only way for the voltage to pass through will be due to the direction of the internal diode.
      Remove all power. Meter in resistance mode. Measure the resistance on the QB5 mosfet:
      source / drain
      source / gate
      gate / drain
      Post each measurement. Each should be hundreds of k ohms or higher else the mosfet may be defective and must be replaced. Confirmation should be done by fluxing and removing QB5 and then measuring again while it is on your work bench.
      • Gokhant
        • Aug 2025
        • 10
        • Danmark
        source / drain
        source / gate
        gate / drain
        Thanks for the reply. I have now measured and ohm and diode mode measurements are ok. Please see attached pic. I think i should follow why the gate voltage is so low. As you mention, the gate should be higher
        • lapfix
          • Mar 2020
          • 2764
          • my workshop
          Upload your schematics or BRD to give you more help
          As mon2 mention before , we don't know the type of QB5 , N or P channel !
          Post all the voltages of your charger circuit too
          • lapfix
            • Mar 2020
            • 2764
            • my workshop
            Just using search at this forum
            Schematics and BRD
            https://www.badcaps.net/forum/troubl...-intel-nm-e211
            Look at P 51 / 89
            • khaahk
              • Dec 2013
              • 812
              • Estonia
              Different mainboard but same case:
              https://www.youtube.com/watch?v=ju6BG40l1xE
              • Gokhant
                • Aug 2025
                • 10
                • Danmark
                I have attached a picture of the QB5 & QB6. Both are of the same chip which is a N channel mosfet. SM3313
                • mon2
                  • Dec 2019
                  • 14662
                  Ok. Remove all power. Repeat resistance checks but use other resistance scales to get a reading. OL = over limit and means the resistance is higher than the selected resistance scale. Post an updated list of measurements.
                  • Gokhant
                    • Aug 2025
                    • 10
                    • Danmark
                    Of QB5 & QB6?
                    I measured them last but all gave OL .
                    Whats expected levels that i can seek for when i measure?
                    • m1ch43lzm
                      • Mar 2019
                      • 919
                      • Peru
                      Maybe it's the same issue since the E15 gen 2
                      https://www.youtube.com/watch?v=7K6XsZkWzJo
                      https://www.youtube.com/watch?v=55oGJArv2oo
                      Root cause appears to be faulty PD controller not driving the MOSFET gates high enough, those 2 videos show a "dodgy" way to fix it, bypassing the input MOSFETs
                      • Gokhant
                        • Aug 2025
                        • 10
                        • Danmark
                        Here are the latest measurements made with 30M ohm range
                        • Gokhant
                          • Aug 2025
                          • 10
                          • Danmark
                          I shorted QB5 and QB6 out while they were in circuit and startet the laptop but it doesnt turned on. And the current consumption which were 2 amp is not there anymore. I removed the short and tried again, and still zero consumption.
                          • mon2
                            • Dec 2019
                            • 14662
                            Bypassing is a hack trick. Not recommended. If it could have been done, the factory would do the same to save pennies and increase their profits.
                            Suspecting that the fuse @ F6101 has triggered. Measure the voltage to ground on each side of the fuse @ F6101. Post the measurements.
                            After this review, solder back QB5. Replace QB6 which is conducting but should not be.
                            Both of these mosfets are N-channel type. For each to turn on fully, the gate voltage should be ~25v but you are @ 20v on this board. The reason QB5 passes the voltage is due to the internal diode. This is ok. Not ok for QB6 because the internal diode is in the reverse direction yet the voltage is passing through. To me, something is wrong here for this mosfet to enable with a 20v at the gate pin.
                            • Gokhant
                              • Aug 2025
                              • 10
                              • Danmark
                              One of the gates has almost 20 but the other one has 9V. So thats a obvious error. I will get back on you with voltage for the fuse
                              • mon2
                                • Dec 2019
                                • 14662
                                At 20v or 9v - both should not enable these N-channel mosfets. The first mosfet can conduct partially because of the direction of the internal diode. This is a low current diode so not enough to power the board. To properly enable each of these N-channel mosfets, the gate voltage should be ~25v. Otherwise, there is something wrong with one or both of these parts. The mosfet driver must also be capable of supplying the boosted adapter voltage of ~25v.
                                • Gokhant
                                  • Aug 2025
                                  • 10
                                  • Danmark
                                  Totally agree on it. i have now measured the fuse and its ok, the 20V is at the both end of the fuse. i have tried to measure on many ic, and even the motherboard is consuming 0.05amp, i manage to find an IC that gets really warm, rest of the board is cold.
                                  • mon2
                                    • Dec 2019
                                    • 14662
                                    Remove all power.
                                    Measure the resistance of PL4201 (+3VALW) to ground. Of concern is if this is a low resistance since the same rail is supplying the PCH / CPU IO pins. What is the resistance in ohms?
                                    • Gokhant
                                      • Aug 2025
                                      • 10
                                      • Danmark
                                      Remove all power.
                                      its 1.1K ohm to ground. I have also taken resistance with respect to ground, of the PU4201 , and attached and i have also noted the voltage of each pin with respect to ground.
                                      I found that the PL7, located on the right side of PL4201, has 0 volt and 0.2 ohm to the ground where it should be : +1.8VALW
                                      • coasterghost
                                        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                        by coasterghost
                                        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                        System Hardware:
                                        Processor: AMD Ryzen 7 PRO 5850U
                                        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                        09-08-2025, 10:46 PM
                                        Lenovo 3000 Series Schematic
                                        Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                        3000 C100 laptop with Braille keyboard
                                        Lenovo 3000 C
                                        C100, C200 - 15-inch XGA screen
                                        Lenovo 3000 N
                                        N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                        N500 - 15.4 inch screen.
                                        Lenovo 3000 V
                                        V100, V200 - 12.1-inch WXGA models
                                        Lenovo 3000 G
                                        G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                        10-04-2024, 06:05 AM
                                        Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                        09-06-2024, 06:40 AM
                                        This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                        09-06-2024, 06:06 AM
                                      • derradji89
                                        Need help Lenovo MIX 320-10lCR domaine name SERCOL
                                        by derradji89
                                        Hi everyone 🤗
                                        I have a Lenovo MIX 320-10lCR computer.**
                                        1. **Operating System**: Windows 10 ** Education** 64-bit.
                                        2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                                        3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                                        4. **BIOS Chip Reflashing**: Currently,...
                                        04-19-2025, 03:04 PM
