Lenovo E15 - NM-E211 doesnt turn on
  • Gokhant
    • Aug 2025
    • 5
    • Danmark
    Im trying troubleshoot a Lenovo E15 which is not turning on.
    Charging Led is ON when charger plugged in.
    PC doesnt turn on when pressing on button.
    Sometimes on button blink 3 times and shut off and repeat it sometime again.
    I took the motherboard out , and connected my in-line dc-meter and it shows 20.16V and 0.00A which for me sounds correct as there are nothing connected , not even battery.
    With everything connected to the motherboard, in-line-dc-meter shows 20.09V and current consumption of 2.1Amps.
    In-line dc-meter restarts like once in every minut.
    PQ4000 is warmer then the rest ,you can easily hold your finger on without burn.
    QB5 and QB6 has 20.02V in and out.
    J5 shows 5.14V
    Any advice on how i should proceed with this?
  • Gokhant
    • Aug 2025
    • 5
    • Danmark
    Here are som measurements
    • mon2
      • Dec 2019
      • 14370
      QB5 may be in trouble. The reason being that the gate voltage is almost the same voltage as the source / drain voltages.
      If the mosfet is a P-channel type, the voltage should not pass through since the gate voltage is not low enough to enable the mosfet.
      If the mosfet is an N-channel type, the voltage should not pass through since the gate voltage is not boosted enough over the 20v on the source / drain pins to enable.
      The only way for the voltage to pass through will be due to the direction of the internal diode.
      Remove all power. Meter in resistance mode. Measure the resistance on the QB5 mosfet:
      source / drain
      source / gate
      gate / drain
      Post each measurement. Each should be hundreds of k ohms or higher else the mosfet may be defective and must be replaced. Confirmation should be done by fluxing and removing QB5 and then measuring again while it is on your work bench.
      • Gokhant
        • Aug 2025
        • 5
        • Danmark
        source / drain
        source / gate
        gate / drain
        Thanks for the reply. I have now measured and ohm and diode mode measurements are ok. Please see attached pic. I think i should follow why the gate voltage is so low. As you mention, the gate should be higher
        • lapfix
          • Mar 2020
          • 2744
          • my workshop
          Upload your schematics or BRD to give you more help
          As mon2 mention before , we don't know the type of QB5 , N or P channel !
          Post all the voltages of your charger circuit too
          • lapfix
            • Mar 2020
            • 2744
            • my workshop
            Just using search at this forum
            Schematics and BRD
            https://www.badcaps.net/forum/troubl...-intel-nm-e211
            Look at P 51 / 89
            • khaahk
              • Dec 2013
              • 786
              • Estonia
              Different mainboard but same case:
              https://www.youtube.com/watch?v=ju6BG40l1xE
              • Gokhant
                • Aug 2025
                • 5
                • Danmark
                I have attached a picture of the QB5 & QB6. Both are of the same chip which is a N channel mosfet. SM3313
                • mon2
                  • Dec 2019
                  • 14370
                  Ok. Remove all power. Repeat resistance checks but use other resistance scales to get a reading. OL = over limit and means the resistance is higher than the selected resistance scale. Post an updated list of measurements.
                  • Gokhant
                    • Aug 2025
                    • 5
                    • Danmark
                    Of QB5 & QB6?
                    I measured them last but all gave OL .
                    Whats expected levels that i can seek for when i measure?
                    • m1ch43lzm
                      • Mar 2019
                      • 501
                      • Peru
                      Maybe it's the same issue since the E15 gen 2
                      https://www.youtube.com/watch?v=7K6XsZkWzJo
                      https://www.youtube.com/watch?v=55oGJArv2oo
                      Root cause appears to be faulty PD controller not driving the MOSFET gates high enough, those 2 videos show a "dodgy" way to fix it, bypassing the input MOSFETs
                        Lenovo 3000 Series Schematic
                        Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                        3000 C100 laptop with Braille keyboard
                        Lenovo 3000 C
                        C100, C200 - 15-inch XGA screen
                        Lenovo 3000 N
                        N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                        N500 - 15.4 inch screen.
                        Lenovo 3000 V
                        V100, V200 - 12.1-inch WXGA models
                        Lenovo 3000 G
                        G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                        10-04-2024, 06:05 AM
                        Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                        This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                        09-06-2024, 06:40 AM
                        This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                        09-06-2024, 06:06 AM
                      • derradji89
                        Need help Lenovo MIX 320-10lCR domaine name SERCOL
                        by derradji89
                        Hi everyone 🤗
                        I have a Lenovo MIX 320-10lCR computer.**
                        1. **Operating System**: Windows 10 ** Education** 64-bit.
                        2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                        3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                        4. **BIOS Chip Reflashing**: Currently,...
                        04-19-2025, 03:04 PM
                        LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
                        This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                        09-12-2024, 02:30 PM
