This machine goes off while near to complete loading bar of mac os....i tried a fresh installation and a new battery also as old battery for this machine was not good...after battery replacement it works fine once and after that again same behavior ...any idea where could be the fault model isA1990 with emc 3215
MacBook Pro A1990
mb code:820-01827-A;
sn:C02Z349ALVDR;
i9 32GB Ram 1TB
Hi, I found short on one of 6 black nand (total 1TB).
i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
macbook with A2141 configuration run on recovery but don't complete it.
anyone can help me?05-26-2025, 09:27 AM -
by robkaHi,
my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
After that the Macbook was dead. It isn't charging anymore.
The USB-C Port where the charger was plugged is burned. Also The Cable and the... -
by DATATECH85Hello,
I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
However, I can't work out exactly why I don't have the PPBUS_G3H rail.
Here are the values... -
by falcontechHi,
I received a 2018 MacBook Pro A1990 for repair, and the motherboard was replaced, presumably purchased on AliExpress. The motherboard's activation is blocked because the previous owner didn't delete it. Does anyone have a solution to this problem? I called Apple, and as expected, they asked me to activate the process with proof of purchase for the original computer, which I find very difficult, so the proof of purchase from AliExpress will be of little use. Any suggestions? Thanks. -
I have a a1990 2018 15 inch MacBook Pro that will not power on.
I have replaced the pch bga chip because it was heating up under my thermal camera.
I have replaced the battery, and replaced the small ic between the gpu and cpu as it had a direct short to ground.
the MacBook now pulls 20v 2.4amps the trackpad clicks but it does not ever attempt to power on not even fan spin. After PCH replacement I was able to get it in dfu mode 1 time and restore bridge OS, but now the MacBook will no longer go into DFU mode.
I have also noticed L7030 gets extremely hot yet... - Loading...
