defective Embedded Controller MSI GF63
  • Patrick501
    • Oct 2024
    • 39
    I located a defective EC (IT557VG-128)on a MS-16R81 2.0 board of a MSI Thin GF63 12U. The board doesn't have any voltages except the 19V power line.
    Some Caps and resistors around the EC show less than 2 ohms. One of them is a 3V rail. When I inject 1V@1A the EC heats up.
    I'm pretty sure I can't just buy and replace it since it probably needs the correct firmware on it.
    Does anyone of you guys know?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    i replaced 5570 and it program itself from bios. so chance is high that u dont need to program it
    • Patrick501
      • Oct 2024
      • 39
      thanks for your answer.
      I will give it a try then. I removed the EC today and the shorts are gone.
      What I'm concerned about is that two CPU coils show a very low resistance to gnd. I know cpu rails can be low but 0.7ohms on this isn't very much.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3628
        • slovakia
        with never gpus and cpus u cannot use common ohmmeter because resitance under 0.5ohm is normal. u must use miliohmmeter, but dont bother with it and just replace EC
        • Patrick501
          • Oct 2024
          • 39
          I changed the EC today. Shorts are gone in this area. Apparently it's working or at least it tried because the USB3.1 controller overheated. There was definitely no power before.
          This computer got here because of an short at or close to the USB-A Port.
          • reformatt
            • Feb 2020
            • 1510
            0.7 ohms seems too low for me for a CPU. If you suspect the fault originated from a USB A port, the first thing to check is the PCH as these ports usually connect directly to it.
            Multiple dead components on a 3V rail usually means dead PCH.
            • Patrick501
              • Oct 2024
              • 39
              this would be a no fix since it's a one chip BGA solution, PCH and CPU.
              • Patrick501
                • Oct 2024
                • 39
                reformatt
                thx a lot for your advice to look for the PCH.
                I have a pretty similar but not the correct boardview and schematic. Only for the previous moldels with the seperated CPU/PCH. So I didn't notice.
                Anyway, the relevant rail shows a low resistance but not zero. When I inject 1V into this 3V3 rail the PCH Chip on the CPU heats up...not very much but if I injected the actual 3v3 it would definitely get hot. Ain't gonna try tho.
                In this case no repair possible Maybe I can find a working mainboard online or the same model with a broken screen...
                • master3112
                  ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                  by master3112
                  I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                  When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                  10-29-2024, 09:32 PM
                • NotEnough
                  Seeking Dell G15 Motherboard ICs for Embedded LED Controller (UEL1 and UEL2)
                  by NotEnough
                  I'm working on a repair for my Dell G15 motherboard (model GDL5L) and need two specific ICs to restore the functionality of the Embedded LED Controller (ELC). The missing components are labeled as UEL1 and UEL2 in the schematic, and they're both critical for LED control and system signaling. Here are the details:
                  1. UEL1
                  • Part Number: SA0000AWJ70
                  • Model: STM32F070CBT6TR_LQFP48_7X7
                  • Function: This microcontroller manages system signaling, power management, and SPI...
                  10-28-2024, 01:44 PM
                • Spikeman
                  Dell Precision 3440 support for CPU 11th gen
                  by Spikeman
                  Hi, since both the Dell Precision 3440 and the Precision 3450 have the same chipset W480.
                  I ask you if it is possible to add the correct microcodes for the Precision 3440.
                  I am adding the list of files that I have extracted from the Bios in order to help you understand if it is feasible.
                  Precision_3440_1.31.0.exe_extracted Precision_3450_1.31.0.exe_extracted
                  03-11-2025, 09:54 AM
                  MSI Gaming Thin GF63 12UCX-608AU Notebook GF Specification for Upgrade or Repair
                  This specification for the MSI Gaming Thin GF63 12UCX-608AU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Thin GF63 12UCX-608AU boardview and Thin GF63 12UCX-608AU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-07-2024, 07:19 AM
                  MSI Gaming Thin GF63 12VE-206XPT Notebook GF Specification for Upgrade or Repair
                  This specification for the MSI Gaming Thin GF63 12VE-206XPT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Thin GF63 12VE-206XPT boardview and Thin GF63 12VE-206XPT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-07-2024, 07:12 AM
