A2337 5v 0.06a-0.45a no power
  • sauce
    • Sep 2013
    • 149
    • France
    I am trying to repair this A2337.
    My USB-C meter stuck at 5v but make some peaks.
    All main voltages fluctuate.
    PPUS_AON 11v to 12.25v and so on.
    I removed F5200 and PPBUS_AON is stable 12.25v
    So I tried to come with my power supply on PPBUS_AON pad (still without F5200 but with USB-C meter plugged in) and I can see my USB-C meter go to 20V but rebooting.
    I also tried to put F5200 back and come with my power supply to battery connector and my USB-C meter go to 20v but still rebooting (but CPU gets hot !)
    Do you have any ideas what to check ?
    With my thermal camera I can see pulses on L8230 and also U8100 near a corner on the same side.
    I checked all capacitors/coils but no shorts at all !
    Thanks in advance.
  • mon2
    • 14663
    Test the voltages on the ssd rails.
    • sauce
      • Sep 2013
      • 149
      • France
      All voltages are fluctuating on SSD rails.
      The only voltages that are stable are from UBC-C :
      PP1V5_UPC0_LDO_CORE 1.582V
      PP3V3_UPC0_LDO 3.4V
      5V on fuses
      PP3V3_S2_UPC is fluctuating
      • mon2
        • 14663
        Remove all power. Measure the resistance to ground of the rails that are not stable.
        • sauce
          • Sep 2013
          • 149
          • France
          ok I try that do you have a list of values somewhere ?
          • mon2
            • 14663
            I do not but in general, if the voltge at the output of the regulator is low, it may be due to a lower than normal resistance on this load = SSDx. Remove all power and measure the resistance to ground. What is the measurement?
            Also, is the enable pin for this power rail also pulsing?
            • sauce
              • Sep 2013
              • 149
              • France
              I think i will stop because i found a knocked off component so this card has been touched by someone else.
              Thank you for your time.
              • chth96
                by chth96
                03-09-2024, 10:03 PM
              • mkdj
                MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                by mkdj
                About me, my goal and the equipment I (don't) have:
                I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                About my issue and my goal:
                A friend of mine has a MacBook Air M1 A2337 that does not...
                04-03-2025, 08:28 AM
              • expertreader
                Dell 5520 not booting up - on light comes on momentarily
                by expertreader
                Dell 5520 South peak 15 MB 213253-1 2TWTT$LA
                Hi all, looking for some help to get started on troubleshooting without schematics
                I have used Dell Latitude 5530 SouthPeak15 MLK 203102-1 schematics from forum although this board is a little bit different.
                I am a bit lost on USBC PD circuit and what to measure - here is what i have done so far.
                • no coils are shorted - one is showing about 15ohms but others are in kohms or infinite resistance.
                • most of the coils are showing 5V, 1.3V, 3V etc except 2 of them.
                • i have measured 16.5V available at the capacitor
                10-19-2025, 08:20 PM
                12-31-2023, 06:04 AM
              • rilley
                MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
                by rilley
                I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
                I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
                My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
                And the resistor L4004 is literally burned.
                From what I see from the schematics, it does not affect any other rails, only the connection to the display...
                07-10-2024, 01:57 AM
