Macbook Air A 2681 Board 820-02536 No turn on
This topic has been answered.
  • Sergio Kub
    • Jul 2018
    • 172
    • Brasil
    I have a Mac A2681 motherboard 820-02536. It was spilled in water. I had already cleaned it with isopropyl alcohol and managed to get it working. However, the keyboard, touchpad, and power button failed.
    A month later, I replaced these components, and the motherboard no longer turns on.
    F5200 resistance: 1 M Ohm
    Stuck at 5V
    Voltage doesn't pass the first transistor, Q5230
    Can anyone help? I couldn't find the sequence.
    I appreciate any tips or collaboration in advance.
  • Answer selected by Sergio Kub at Today, 04:33 PM.
    Sergio Kub
    • Jul 2018
    • 172
    • Brasil
    C BMU SYS_DETECT NOTES
    The BMU SYS_DETECT circuit relies on the system assembly in order to be properly enabled.
    During assembly, a metal gasket is placed between the cowling and the top-side of the BMU flex.
    The gasket is used to connect the BMU_CWL_DET_L signal, located between J5150.1 and Q5190.2,
    to GND. Once BMU_CWL_DET_L is tied to GND, then the SYS_DETECT circuit is ready to be enabled.
    The BMU VBAT output will be enabled after the BMU flex and cowling are installed and power is
    supplied by connecting a power adapter to either the USB-C or MagSafe Connectors.
    Thus the MLB remains in an unpowered state during system assembly.
    Once the MLB is assembled into an enclosure, the BMU SYS_DETECT circuit output, SYS_DETECT_L,
    is continuously sampled by the Gas Gauge IC at a rate of once per second until it detects a logic low.
    During the once per second interval, an internal pull-up within the Gas Gauge IC is enabled for 4us to conserve
    battery charge. Once a logic low is detected, then the BMU enables the VBAT outptu voltage.
    • mon2
      • Dec 2019
      • 14394
      ?? Power up and measure the voltage to ground on each side of F5200. Post the measurements. If this is the measurement across F5200 then the fuse is blown and needs to be replaced.
      Without power to the board, measure the resistance to ground on each side of F5200. If the fuse is not blown, this measurement should be the same on each side.
      • Sergio Kub
        • Jul 2018
        • 172
        • Brasil
        Thanks for responding.
        The fuse is not blown.
        Without power to the board, the resistance measurement on the F5022 is high, around 1M Ohm.
        The voltage does not pass through Q5230, right at the input.
        • mon2
          • Dec 2019
          • 14394
          Share the voltage to ground measurements of each pin on q5230:
          source
          gate
          drain
          • Sergio Kub
            • Jul 2018
            • 172
            • Brasil
            It is a double transistor
            First
            Pin 3, 4 and 5 D - 5V
            Pin 6 G - 0V
            Pin 7 S - 0V
            Consequently, the second transistor with all pins 0V,
            • mon2
              • Dec 2019
              • 14394
              Remove all power. Meter in resistance mode.
              Measure the resistance across:
              source & drain
              source & gate
              gate & drain
              post each measurement.
              • Sergio Kub
                • Jul 2018
                • 172
                • Brasil
                S - D 700 K Ohm
                S - G 350 K Ohm
                G -D 6.37 M Ohm
                • Sergio Kub
                  • Jul 2018
                  • 172
                  • Brasil
                  Q5230 / 2
                  S - D 800K Ohm
                  S - G 700K Ohm
                  G - D 427K Ohm
                  • mon2
                    • Dec 2019
                    • 14394
                    The G-D measurement may be a bit low for the mosfet. Suggest to flux and remove this mosfet. Leave the mosfet off the board. Then power up again.
                    Does the first mosfet enable without this 2nd mosfet on the board?
                    • Sergio Kub
                      • Jul 2018
                      • 172
                      • Brasil
                      Q5230 are 2 transistors in the same package. It's dual.
                      Should I remove the first one anyway?
                      • Sergio Kub
                        • Jul 2018
                        • 172
                        • Brasil
                        There are two dual MOSFETs at the power input, Q5230 and Q5240.
                        The resistances measured were from the two MOSFETs in the first package. Q5230
                        • Sergio Kub
                          • Jul 2018
                          • 172
                          • Brasil
                          I tested only with Q5230, without Q5240 and then swapped one with the other (they are the same). The Q5230 Gate is not activated by U5200. What signal would give the OK for the IC to activate the Q5230 input? It is not activating the MOSFET first because there may be something wrong ahead, like a short circuit.v
                          • Sergio Kub
                            • Jul 2018
                            • 172
                            • Brasil
                            • Sergio Kub
                              • Jul 2018
                              • 172
                              • Brasil
                              I think that's the problem, but I still don't know how to activate the battery.
                              • m1ch43lzm
                                by m1ch43lzm
                                05-12-2025, 08:37 PM
                              • Rezendes
                                Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                                by Rezendes
                                Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                                I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                                The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                                05-10-2024, 02:18 PM
                              • tony359
                                2007 Macbook logic board fault
                                by tony359
                                Good day all,
                                I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
                                Once the fan was swapped, I installed an OS and it worked fine.
                                The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
                                Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
                                If I see that right, I have missed VCORE on L7100 (page 59)....
                                01-23-2025, 06:59 AM
                              • slimmy182
                                MacBook M1 Pro 14" 2021 A2442 (820-02098) — U2020 getting hot, board not powering on
                                by slimmy182
                                I have a MacBook Pro M1 14” (board 820-02098) with a broken LCD panel (matrix damaged).
                                The board does not power on — when connected to power it draws about 5.1 V / 0.474 A (~2.45 W) and stays at that level, with no fan spin or display activity.
                                Using a thermal camera, I noticed that U2020 heats up to over 70 °C shortly after connecting power.
                                According to the schematic, U2020 is a SN74AVC2T45RSWR (Texas Instruments) 2-bit bidirectional level shifter.
                                There are no visible signs of liquid damage anywhere on the board.
                                Given the broken LCD,...
                                08-15-2025, 02:57 AM
