HP 15-ec2531nd switching off
  • dr.thodt
    • Apr 2016
    • 80
    • Netherlands
    I have an HP 15-ec2531nd here which does the following:
    - Turns on. One of both fans goes full throttle. Other doesn't spin up.
    - BIOS works.
    - All self tests pass, except smart pin. Not even with another adapter connected.
    - RAM is ok.
    - RAM slot pins are ok.
    - Battery is ok.
    Whenever I want to boot Windows from m2 SSD system switches off.
    I have a USB stick with several tools on it, including Windows PE. I can browse this stick's menu, but when I start Windows PE, the laptop switches off at the same point where it would when booting Windows from m2.
    Is the EC a suspect? Are there other things I could think of?
    Thanks for your attention.
  • mon2
    • 14086
    Smart pin = power adapter ID pin? What is the exact error?
    • dr.thodt
      • Apr 2016
      • 80
      • Netherlands
      Self diagnose says the pin might be bent, which it isn't. Will check tomorrow for the exact message.
      The laptop's behavior is no different with the adapter unplugged.
      • mon2
        • 14086
        HP uses an analog voltage to identify the power adapter rating. This voltage is sampled by an analog to digital converter by the EC. Perhaps this voltage is missing.
        • dr.thodt
          • Apr 2016
          • 80
          • Netherlands
          Perhaps, and something I will investigate. But as said, the issue occurs as well when running from battery. The smart pin should not be an issue then. Unless it is.
            03-31-2024, 02:12 PM
            07-01-2024, 06:34 AM
            After all of...
            07-13-2024, 08:14 PM
            DVR camera recorder switching power supply capacitor failure really
            These cheap non brand capacitors at it again
            Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
            Well at least I have the cameras back on line I to try the...
            01-22-2022, 06:28 PM
            Used a Ring tester to troubleshoot a switching power supply that has a blowed fuse
            I found this switching power which has a blowed fuse checked diodes which were still good out of circuit checked main filtering capacitor with an ESR meter 220uf@450 volts 0.15 value which to me seem bad but maybe not but without these items not in the circuit because I have about 8 ohm on the output of the capacitors so I removed the switching power supply transformer and checked it with a ring tester and all but one winding showed good all others either showed two red lights or no lights on and one winding had all lights on which was the only one that was good
            One other check that...
            08-03-2021, 06:41 PM
