MBA13 M3 2024 A3113 EMC8611 820-03285 No Trackpad No Keyboard (water damaged)
  • guzq
    • May 2017
    • 54
    • Indonesia
    Hi Guys,
    This Mac come with dead issues (severe water damage), now it’s turning ON except Trackpad and Keyboard not working.
    Already check and write down DM for JT400 and JT201 don’t find any abnormal value (I don’t have unit for compare).
    Already try,
    • Replacing Trackpad Flex Cable
    • Replacing New Trackpad
    • Replacing Little Board (Daughter Board)
    • Try using New Keyboard
    Still no change at all, Trackpad and Keyboard not working.
    So I check “Power Load Switches” and this is all the numbers,
    UC830 > 1 = 3.297V ; 3 =1.757V ; 4 = 3.798V
    UC840 > 1 = 0V ; 2 = 1.878V ; 3/4 = 5.187V ; 5 = 5.187V ; 6 = 0V ; 7 = 0V
    UC850 > 1 = 0V ; 2 = 1.796V ; 3/4 =12.56V ; 5 = 12.56V ; 6 = 0V ; 7 = 0V
    UC860 > 1 = 0V ; 2 = 0V ; 4 = 0V ; 5 = 1.798V
    UC870 > 1 = 1.801V ; 2 = 1.798V ; 4 = 1.797V ; 5 = 1.798V
    Now I hit dead-wall what should I check next ?
  • ronaldopdias
    A3113 corrosion to LAS = No keyboard, yet screen and trackpad work fine
    by ronaldopdias
    Hi All.
    I have a A3113 MacBook Air 13" (M3) that had minor liquid damage. The screen remains on if the lid is closed, the keyboard doesn't work, but trackpad and Touch ID does.​
    The LAS was corroded, but I have tested it on an A2681 (M2) and it functions fine. Anyway, I ordered a new one and replaced it and calibrated it with Apple.
    I have checked the main voltages going to the daughterboard and they are present. Diode mode reading on the LAS line which goes direct to the SoC is also correct, no short.
    So then I replaced the daughterboard, and...
    06-16-2025, 03:12 AM
  • rynr
    MacBook Air (13-inch, M3, 2024) Model A3113 Schematics & Boardview
    by rynr
    Hi friends,
    can somebody provide schematics and boardview for A3113?
    Thanks in advance
    09-28-2024, 04:16 AM
  • mitchw
    MacBook Pro M4 Pro - no keyboard / trackpad / lid sensor
    by mitchw
    Hello
    I got this MacBook Pro M4 Pro to have a look at.
    It was tiny bit liquid damaged, just the edge of the board got 1 small 10x10 mm area wet. I've seen much worse that still worked fine to be honest.
    Since it was liquid damaged, warranty does not apply anymore.
    Anyways it was checked at an local Apple Store and they discovered that it needs new trackpad, new top case, etc. Also it needed a new lid angle sensor which they replaced.
    The main issue was that the screen remained black.
    Anyways I cleaned the liquid damaged area, put the machine back...
    09-06-2025, 07:19 AM
  • No Lan
    [Macbook pro A1708] [Boot loop] [Trackpad ?]
    by No Lan
    Hey everyone,
    Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
    Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
    Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
    05-24-2025, 03:09 PM
  • iMuhtaseb
    A2681 Keyboard, trackpad and sleep?!
    by iMuhtaseb
    Wow it's been a while since I posted!
    This is a weird case, it has a history of liquid spill a year ago but customer did not want to replace neither trackpad or keyboard.. fast forward for today:
    A2681 turns on but not trackpad or keyboard feedback (or external keyboard and mouse) and then after a minute or so the Mac sleeps..
    It's a NOT a sleep sensor or trackpad or keyboard or daughterboard or anything else (I replaced all those); it's the logic board..
    Tested another locked logic board on customer's top case and it posted with keyboard and...
    05-22-2025, 09:59 AM
