Help identify this chip please folks....
  • Loki_Fido
    • Mar 2025
    • 126
    • Japan
    Hi folks,
    Hope everyone's doing well.
    I have a HP ProBook 450 G9 came in for repair. This driver is shorted and im looking to buy a replacement. But i cant identify this chip.
    I checked our BadCaps sticky on following site
    https://www.badcaps.net/forum/troubl...and-datasheets
    But the name of the chip is wrong. I checked based on GND on chip.
    If you check on above link, you'll think this chip is SY8388ARHC, but if you search for it on the web, you'll see a different chip.
    Any help is appreciated.
    I love you all,
    I love this site
    Make HP ProBook
    Model 450 G9
    ProdID 6W856PA#ABJ
    SN# 5CD2257NJD
    • 21841
    That was a mistake in the list .Now it`s ok R9*** SY8388B3RHC N/D (NM-C771)
    • R_J
      • 9600
      Here is the datasheet for silergy SY8388B3 with top mark R9xyz
      • Loki_Fido
        • Mar 2025
        • 126
        • Japan
        Hi SMDFlea,
        You're the man.
        Thanks a million.
        • Loki_Fido
          • Mar 2025
          • 126
          • Japan
          Thanks a million R_J
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
          • Tyroonis
            Identify component - QPF Chip from Eufy Robovac L70 Hybrid Vacuum Cleaner
            by Tyroonis
            I have a robot vacuum cleaner here.
            An Eufy Robovac L70 Hybrid.
            A chip has burst due to a short circuit.
            The following is legible on the chip:
            Mpsm44
            m2612
            883138
            I'm not sure if there is another number after m2612, as that's exactly where the hole is.
            Can anyone help me identify what this component is?
            Unfortunately, I couldn't find anything.
            I also don't have any plans or board views of the...
            08-14-2025, 02:32 PM
          • hoak
            Help me identify this burnt chip
            by hoak
            I have a Asus Q540v laptop which has no power. I opened the laptop and found this burnt chip. Unfortunately, the marking on the chip is damaged. Anyone able to identify this chip?
            THanks,
            07-05-2025, 07:58 PM
            by SMDFlea
            Bad...
            09-02-2021, 04:40 PM
