216-0707009 compatibility?
  • MDY
    • Jan 2014
    • 75
    • Spain
    I have problems with this GPU - 216-0707009
    I have 216-0707001 and 216-0707011. Are they compatible with 216-0707009?
  • sopik78
    • Nov 2013
    • 517
    • Czech Republic
    Re: 216-0707009 compatibility?
    Take a look here: http://hardware-today.com/articles/n..._compatibility
    • MDY
      • Jan 2014
      • 75
      • Spain
      I know this page and they dont...
      • highpulse
        i hate HP
        • May 2013
        • 1488
        • portugal
        then its complicated , only if you try mate . but usually i recommend to try this with a test board or else you could damage something in the board itself
        • jean luc ferre
          laptop hp g72 b52sf screen problems
          by jean luc ferre
          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
          06-07-2025, 03:27 PM
        • Hondaman
          USB problems?
          by Hondaman
          Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
          (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
          I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
          08-12-2024, 03:26 PM
        • clabr
          Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
          by clabr
          Need help to solve some problems with this laptop.
          After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
          After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
          Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
          Before this had happened I observed some other problems:
          When I tried replacing original mecanical HDD with a SSD HDD could not get them...
          12-02-2021, 08:09 AM
        • 2wtn
          CD3217B12 compatibility
          by 2wtn
          Hi all, have been lurking here for quite some time, and now my first post
          People who have experience replacing CD3217B12 chips (on macbooks), I have a few questions for you.
          As far as I understand, the CD3217B12 exists in more than one type and the different types are not cross-compatible. Is that correct? How many types are there in fact that you know of and which motherboards is each type compatible with? Do they look visually the same, or is there some difference in marking?
          What should I look at when buying these chips online, for example on...
          12-14-2022, 08:17 AM
        • Admin
          Other Useful Threads - Laptop Screen Compatibility, Useful ICs, BGA Chip Suppliers, NVidia bumpgate
          by Admin
          Some sticky topics have been moved to this thread:
          - finding a compatible laptop screen with LED-backlight.
          Most Common ICs - a list of the most common ICs (Integrated Circuits) required for repairing a laptop
          MOST COMMON IC FOR LAPTOP YOU SHOULD HAVE IN STOCK
          Let's Talk About BGA Chip Suppliers - anyone who repairs computers at component level has had to order chips from China at some point. Large BGA chips like graphics chips, chipsets and now CPUs are in increasing demand, due to their...
          12-27-2023, 03:43 AM
