Need help diagnosing the NM-D471 REV 2.0 motherboard for a LENOVO laptop.
  • JJ8409
    • Jun 2025
    • 3
    • France
    I need your help with an issue I'm encountering while diagnosing a NM-D471 REV 2.0 motherboard from a Lenovo laptop. The laptop won’t power on. I started by checking the power rails, including the main power line and the 3.3V and 5V rails.
    I do have a proper 3.3V across the line, including at the chip responsible for managing 3.3V/5V—same goes for the 5V rail. I haven’t tried to simulate a power-on yet, since the main issue still needs to be resolved.
    I have full access to the boardview, but I’m not sure what to check next to isolate the problem.
    However, I believe I’ve detected a short circuit on the PWR_CPU_PWR decoupling line, particularly starting from capacitor PC1026 (which appears to be a polarized capacitor, please correct me if I’m wrong). The two other nearby capacitors on the same line also seem to be shorted.
    I have already removed those components from the board, but the short circuit still remains.
    Do you have any idea what could be causing this, or suggestions on how to trace the faulty component?
  • Bonzas
    • 472
    • Indonesia
    how do you know those line is shorted ? because have low resistance ? how much resistance you get there ?
    • JJ8409
      • Jun 2025
      • 3
      • France
      Starting from the polarized capacitor PC1026, in continuity mode I get a beep on each pad as well as on all components along the line.
      In resistance mode, I measure 0.23 ohms across capacitor PC1026.
      • Bonzas
        • 472
        • Indonesia
        so, you already measure other voltage that missing from the board right ?
        You have short on 19v line or no ? if no short on 19v, 5v, 3v line. I think you can measure what voltage that missing on your board before judge the cpu line shorted.
        • andrhouseolly
          Lenovo X240 - motherboard replacement for X250, no image.
          by andrhouseolly
          Friends. I beg you to help me in this situation.
          Lenovo X240 with a video problem. Native Intel drivers are not installed,
          after installation, a black screen. It works with the standard Microsoft driver.
          Understanding that there are problems with the video core,
          I ordered a motherboard from Lenovo X250.
          The laptop turns on, starts up, there is no image on the internal display.
          The image is output to the external monitor.
          I ordered another motherboard from Lenovo X250.
          07-12-2024, 03:02 PM
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
        • rddube
          Need help interpreting schematic of Lenovo B470 motherboard
          by rddube
          OK, so here is my issue.
          This Lenovo B470 motherboard I am troubleshooting died and I identified it is the discrete Nvidia graphics chip that has lost it's ways!
          So I removed it and now I am trying to change this motherboard to use UMA graphics, but I am having an issue interpreting the attached diagram. I have a 10K resistor in at the R2013 position and another one at the R2012. R2010 and R2011 are empty.
          The motherboard starts, the fan spins but no display. It turns off by itself. I restart it and it does start but stays on...
          08-12-2024, 02:01 PM
        • laup
          Lenovo 330s-ARR-R332200U motherboard remove on board ram
          by laup
          ive looked through all the lines for 2311 but cant see a consistant row of them
          could someone please have a look at my bios and remove the onboard from within, appreciate it
          Laptop : Lenovo 330s 15 ARR
          motherboard: 330s-ARR-R332200
          SN: yd04qytm...
          Yesterday, 07:23 AM
        • lezsimply
          Low resistance reading on 3v line, Asus Prime H310M-A R2.0 desktop motherboard
          by lezsimply
          Hello Everyone and Good Day,
          I've got an issue with this desktop motherboard. It does not power on, Asus Prime H310M-A R2.0. I tested 33ohms reading on 3v line on the ATX connector. It beeps on continuity mode. I tried injecting voltage from 0.9v at 1.5amps and no current being drawn. I raised the voltage to 3v @ 4amps and now I only get 22mA on current. I checked with thermal camera and there is no part heating up. I'm afraid of going further the safe voltage. What could possibly causing the line to be shorted. 5vsb has no short. I get 0.9v on positive pin of power switch. There's...
          11-22-2024, 03:14 AM
