Toshiba L855-10P Totally Dead
  • grahamw01
    • 256
    I have a Toshiba L855 10P laptop that is completely dead, I am trying to fix it for a friend and i have had some luck on this forum with laptops in the past so I hope you geniuses can help me again
    Apparently it just completely died one day and would not turn on, no fans, lights, not even the charging light comes on when its plugged in. I have already tried a new power supply, and I have checked the voltage in to the motherboard and it is receiving 19.5V, I also checked the visible fuses and they seem fine.
    The motherboard model is DK10FG-6050A2509901-MB-A02 Rev 2.0.
    It has a sticker for InsydeH20 BIOS inside, and the bios chip is a Winbond 25032BVSIG if it helps!
    Many Thanks,
    Graham
  • dj_ricoh
    • 2073
    Re: Toshiba L855-10P Totally Dead
    hello again!
    if there is no schematic you need to find all the QFN chips and the sio chip
    KB controller .
    then we can see where the voltage stops.
    p.s. photos! not potato photos
    • grahamw01
      • 256
      Hello again!
      The reason I stated the BIOS chip is because it has the same chip as the last laptop you helped me with (still working fine by the way!) and it had exactly the same symptoms. I don't think he tried to flash the BIOS here though.
      I have attached some pictures, I have tested voltages across Q6010, Q6011 and Q6012, I think these are mosfets to do with the power input (TPCA 8065-H), I think 1 of them had 19V and 2 had 3V.. I can't remember if that is correct though. I think U6000 is the chip that controls the power input.
      Thanks!
      Graham
      • dj_ricoh
        • 2073
        I will suggest not to continue but I guess you want!
        reason why not ,in the first and second pic. you can see the solder released the flux from it.
        so uber preheated or the ... my old friend OVEN.
        the chase for the oven came bigger when I saw it had a video chip dedicated.
        p.s. I was talking about QFN chips find the models and lets find the charging circuit first.
        • grahamw01
          • 256
          Yes I oven'd it, I thought maybe just a bad solder joint somewhere
          I found this thread with a similar motherboard and similar problems, but this person reversed polarity of the input voltage which is why, not the case here.
          https://www.badcaps.net/forum/showthread.php?p=465244
          U6000 is the same here, and someone said "AC detect/charger section which is controlled by the IC U6000." This is a QFN model BQ25A, you can see in first attached picture.
          Graham
          • dj_ricoh
            • 2073
            Graham
            ok!
            lets do this
            the QFN chip that u6000(I attach a pic)
            write down the values and post it; left to right.
            • grahamw01
              • 256
              hello!
              Here are the voltages for each pin, the only pin i cant test is 18
              1. 7 - 7.5
              2. 7 - 7.5
              3. 7 - 7.5
              4. 7 - 7.5
              5. 0
              6. 2.685
              7. 0
              8. 0
              9. 0
              10. 0
              11. 3.1
              12. 3.1
              13. 3.1
              14. 0
              15. 0
              16. 6
              17. 5.85
              18. -
              19. 3.1
              20. 19.05
              Pins 1-4 cycled between 7V and 7.5V and the rest stayed at the numbers above.
              Also FUSE6050 (for battery) is 3.1V if it helps..
              Graham
              • dj_ricoh
                • 2073
                something its wrong there on those first 4 pins
                find the fets from the jack maybe we can see where is coming from
                • atsio
                  • Oct 2013
                  • 819
                  • Greece
                  Check resistance to ground on all pins of Q6011
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3597
                    • slovakia
                    acok is missing so no energy come through. must resolve acok signal
                    • grahamw01
                      • 256
                      Hi everyone, thanks for your comments, the 3 mosfets i can see are below with resistances to ground;
                      Q6010: pins 1-3; 0.58kOhm. pin 4; 0.69kOhm. pins 5-8; 22.7kOhm.
                      Q6011: pins 1-3; 0.58kOhm. pin 4; 0.69kOhm. pins 5-8; 0.58kOhm.
                      Q6012: pins 1-3; 5MOhm. pin 4; 15MOhm. pins 5-8; 0.58kOhm
                      thanks!
                      • dellxps15
                        • Feb 2014
                        • 1588
                        • italy
                        i see a nuvon controller. maybe this laptop got kb bios ?
                        • khaahk
                          • Dec 2013
                          • 776
                          • Estonia
                          BQ24725 should pull ACOK high when pin 6 is 2.68V, i think you need to chenge the BQ24725
                          • grahamw01
                            • 256
                            so the mosfets are okay with those values?
                            dellxps15 the bios is insydeH20
                            khaahk are you sure or could something else be causing the problem on U6000? I would not be so good at changing the QFN :P
                            thanks!
                            • dj_ricoh
                              • 2073
                              one thing before changing that QFN chip , charge the battery somewhere and see if it works with only battery!
                              • dj_ricoh
                                • 2073
                                without schematic its hard!
                                I will have suggested to power with wires from battery connector :P
                                • khaahk
                                  • Dec 2013
                                  • 776
                                  • Estonia
                                  If possible do so.
                                  QFN is the most likely failed component. Can't be 100% sure.
                                  • atsio
                                    • Oct 2013
                                    • 819
                                    • Greece
                                    What is the voltage on all pins of D6000 and D6002?
                                    • grahamw01
                                      • 256
                                      wow guys, managed to charge the battery a bit on my ancient Toshiba L350, good job I kept it all these years! The laptop works fine off the battery!! So what does this mean?
                                      atsio - I don't know the pin numbers but;
                                      D6000 top left; flickers between 6.9V and 7.5V. top right; 19.35V. middle bottom; 19.09V
                                      D6002 top left; flickers between 6.9V and 7.8V. top right; 2.69V. middle bottom; flickers between 7.5V and 8.5V.
                                      thanks!
                                      • cyberhack
                                        • Feb 2013
                                        • 466
                                        • Uk
                                        Hi atsio have you got schematic
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          09-06-2024, 05:33 AM
