Thinkpad L15 Gen 1 freeze on battery
  • tomodachi
    • Apr 2012
    • 612
    • Turkey
    ThinkPad L15 Gen 1 with AMD Processor
    Motherboard code : NM-C741 REV: 1.0
    The laptop works flawlessly when connected to an AC power source, and the battery is in very good condition (30 cycles, original battery).
    However, when the adapter is unplugged, the system freezes within approximately 20–30 seconds and becomes completely unresponsive. Sometimes, this is followed by a blue screen with the error code "DPC_WATCHDOG_VIOLATION".
    Sometimes it restart itself and sometimes screen goes blank..
    Here's what I've tried so far to resolve the issue:
    • CPU reballed
    • EC replaced
    • A different battery
    • Core PWM IC replacement
    Thank you in advance for your suggestions.
    Here is the link to schematic
    https://www.badcaps.net/forum/troubl...c741-schematic
  • tomodachi
    • Apr 2012
    • 612
    • Turkey
    I assume I2C_CLK_BT, I2C_DATA_BT​ lines are good since there is no problem with charging the battery
    • Sephir0th
      • Oct 2020
      • 1289
      The logical suggestion is to try with another known working battery. To start with.
      FairRepair on YouTube
      • tomodachi
        • Apr 2012
        • 612
        • Turkey
        Thank you for suggestion. But as I mentioned, I already tried with another battery.
        • Sephir0th
          • Oct 2020
          • 1289
          Missed this detail...
          Maybe something wrong with one of the Buck converters possibly not able to buck stable from a lower voltage main power rail.
          Do measure a abnormal current draw from charger by any chance?
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • rumpumpel1
            ThinkPad T490s only starts with battery
            by rumpumpel1
            I am testing a ThinkPad T490s with this setup: only the bare mainboard NM-B891 with a fan and the small Power-On daughterboard as well as with a USB-C monitor (no BIOS battery!).
            If I connect a battery, the mainboard starts up normally. After about 50 seconds the logo appears and after another 30 seconds the final message “... System configuration is invalid. Press Esc to continue or F1 to enter setup”.
            If I connect the power supply unit instead of the battery, a USB meter shows the usual fluctuating power consumption for approx. 30 seconds, then the mainboard switches off...
            12-02-2024, 01:42 PM
          • Grafnus
            Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
            by Grafnus
            Hey there,
            first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
            So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
            Specs:
            • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
            • CPU, GPU, RAM work fine (not involved in the Problem)
            So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
            Now I noticed...
            08-06-2025, 11:54 AM
          • bykanovm
            Thinkpad W541 Works from the mains and charges the battery only when it is turned off
            by bykanovm
            Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
            If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
            If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
            even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
            Also, the laptop does not turn on without...
            04-02-2025, 02:45 AM
          • mkdj
            by mkdj
            Mark and model: ASUS X571
            Tests already made:
            - I have removed...
            07-14-2025, 09:16 AM
